Old 11-09-2007, 08:22 AM
barnon is on a distinguished road
Etching with Plasma?
I have a CNC Plasma table and was wondering if it's possible to etch, say a patent number into steel by running the table on low current and high speed. Anyone ever try this?
Thx for any info.
Old 11-10-2007, 09:16 AM
Torchhead is on a distinguished road
The etching I have done with plasma has all been by mistake (:-). There will be a couple of problems with the approach: 1. You will get inconsistant width especailly if the metal is not perfectly flat so your tip to surface stays constant. The THC MIGHT be able to be set to hold a constant height but it will take a lot of experimenting. The feedrate will need to be pretty constant which is contra to doing small letters with lots of curves. 2. it will wear out tips a lot faster even at the lower current.
Try it with everything set on manual. I would think you would get better results with smaller tips but the results I got by mistake left a pretty wide trench. Maybe if the letters were over 1/2" tall it might be acceptable.
I would think a carbide tip from a TIG and running with a lower voltage high current supply might do a better job but once again it's pure speculation. you might even be able to use a THC that was modified to work at the lower voltage to hold constant height. The DC supply needs to be constant current.
Tom Caudle
www.candcnc.com
Etching Stainless steel Smackre Engraving Machines 5 07-21-2008 12:35 AM
computer- etching jbacon General Metal Working Machines 0 05-28-2007 03:20 PM
PCB milling/etching dberndt Employment Opportunity 4 05-17-2005 03:54 PM
etching glass or mirrors turkgeltz Glass, Plastic and Stone 23 01-09-2004 12:02 PM
Circut board etching WOODKNACK General Electronics Discussion 10 05-19-2003 07:06 PM
