I'm trying to find an oxygen valve for pierce/cut on a cnc oxy/fuel table. I have looked the better part of the day with no results. Someone said I could use a CO2/argon type gas solenoid. Will this work or does anyone know where I can get a valve. |
| AFAIK you should be able to use any Pneumatic valve for Oxygen, of a suitable capacity? Linde used ASCO on their machines for many years. Al.
| ASCO has a valve that is oxygen ready and is assembled free of any oils that could ignite and blow you up . They charge for that service too.I would contact ASCO and inquire about which valve is they suggest. This link explains the de-greasing and black light inspections required to protect their rear-ends. http://www.lesman.com/unleashd/catal...s/asco_opt.pdf Good luck! Tom |
Ok...well I of coarse didn't have a part number thats why I'm calling them for help. Ended up going down the list of valve options to determine what I needed and got to the voltage option. (Aparently I have already taken too much of his time at this point because he is an even bigger prick than when we started) I finally got sick of his whole attitude and hung the phone up. Needless to say I still dont have a valve and am writing a letter to his Boss. The ASCO valves will fit the bill but I refuse to buy them from the local dealer. Any other valve maker that will work? Sorry for the rant. Last edited by roady89; 10-03-2007 at 09:20 AM. |
| Call ASCO and get them to spec your valve. Then call McMaster or Grainger and spend your hard earned $$$ with someone who cares. Calling that guys manager is a must do also. Just hope you are speaking to the real boss. Tom |
| I have used a 110V valve robbed from a wire feeder (argon/Co2) for several years. It's on an old Linde pantograph torch. As I remember I took it apart & cleaned it first with a solvent cleaner then followed up with denatured alcohol & re-assembled.
__________________ If it works.....Don't fix it! |
| Roady, I'll get you the model & SN off of my ASCO valve tomorrow. I don't know why I didn't think of this sooner. As millman mentioned you could clean any valve and get away with it I suppose. ASCO has a huge liability they are having to address. |
| Im in the same boat. Looking for an oxygen rated solenoid valve. Ive just about resigned myself to using a gas saver and just using the oxygen side with my own solenoid or linear actuator to energize it. http://store.weldingdepot.com/cgi/we...ml?id=47XwbViy I might even use two of them and let the machine light and extinguish the torch itself. |
| Plasmaguy, Thank You very much for the information. I greatly appreciate it. |
#12
| Heres the part number I ordered plus a few more similar ones. http://www.grainger.com/Grainger/items/3UL51 (picked up for $59.35) http://www.grainger.com/Grainger/items/3UL56 http://www.grainger.com/Grainger/items/3UL57 ($110, For Hazardous Locations) Theres a few more on there too. |
| Alu Engine to run on water (Hydrogen + Oxygen) | ADucci | I.C. Engines | 42 | 07-01-2007 05:24 PM |
| solenoid help | jimini | Printing, Scanners, Vinyl cutting and Plotters | 2 | 02-13-2007 12:15 AM |
| Pneumatic solenoid help | Cold Fusion | CNCzone Club House | 3 | 05-29-2006 12:46 AM |
| C02 laser cutting and oxygen safety | owhite | Laser Engraving & Cutting Machines | 5 | 04-01-2005 08:30 AM |
| Solenoid Z-Axis? | chuckknigh | DIY-CNC Router Table Machines | 14 | 10-08-2003 06:57 PM |
