Old 09-18-2007, 11:42 AM
DZstar is on a distinguished road
My CNC Plasma Cutting Table
Hi all,
I have been looking at owing a cnc plasma cutting table as a hobby since early this year, but being living in Algeria was not that easy to get good qoutes for shipping and after that paying customs (50%) for the parts imported, besides I didn't have that much money to spent (same old story), so I decided on building one if possible.
As most of you out there, I searched the internet for months and downloaded lots of documents and images, finally I went through and made a simple design out of the images i downloaded from the internet.
to make the story short I will post the pictures here, the table table is finally ready , what I miss is the THC and the plasma cutter which I have not decided to which one I should buy yet and need your help guys on this one, there is not much of choices locally but I will list them and you can help me.
I bought the controller from Damen CNC in the netherlands from Kevin, price was good and shipping was by DHL fast and easy.
here is some pictures and if intretsed I can post more,
Regards,
Dzstar
ID:	43894   Click image for larger version
ID:	43895   Click image for larger version
ID:	43896   Click image for larger version
ID:	43898   Click image for larger version
ID:	43899   Click image for larger version
ID:	43900   Click image for larger version
ID:	43902   Click image for larger version
ID:	43903   Click image for larger version
ID:	43904   Click image for larger version
ID:	43906   Click image for larger version
ID:	43907   Click image for larger version
ID:	43908   Click image for larger version
ID:	43910   Click image for larger version
ID:	43911   Click image for larger version
ID:	43912   Click image for larger version
ID:	43914   Click image for larger version
ID:	43915   Click image for larger version
ID:	43916   Click image for larger version
Old 09-18-2007, 10:57 PM
xjdubber is on a distinguished road
Looks good, i would go for hypertherm for the plasma cutter. IMHO I would have gone with candcnc.com for the controller it would have had thc with it.
Old 09-19-2007, 02:57 AM
I couldn't find hybertherm in Algeria, what i found is the following:
Esab LPH 35
Esab LPH 80
Esab Powercut 650
Esab powercut 875
SAF ZIP 2.0
SAF ZIP 4.0
FIMER 40
I planning to cut 3mm to 5mm mostly and 8mm occasionally.
I will consider candcnc for the next order , i will contact them to see the shipping cost from the US to here.
Old 09-19-2007, 09:12 AM
Weldtutor's Avatar
Weldtutor is on a distinguished road
Arrow Great Work
Esab LPH 35
Esab LPH 80
Hi DZstar & welcome to CNC zone!
Great work on the construction of your CNC plasma table. The bearing mounting method is interesting & should work well.
Thanks for sharing the photos of your project which is sure to inspire others.
The Esab units in the quote above should work for your material thicknesses, with the #80 preferred for heavier sections.
Keep us posted as you complete your build.
Old 09-19-2007, 09:38 AM
Weldtutor,
Thanks for the kind words, I wanted to give back something this forum where i learned a lot on the cnc plasma.
I will also post the cad files i designed for the Y axis ( it is not was finally came out because of my poor drilling technique, but should be helpful if someone wants to modify the dimensions)
the thing that I don't understand is the difference between LPH 80 and powercut 875 , both seems to cut similar thicknesses , can you please tell me what? is it something about the HF torch thing!! and why the HF is imporatnt (or not)?
Old 09-19-2007, 04:47 PM
energyforce is on a distinguished road
Does HF stand for high frequency. I know with TIG welding you have something called a high frequency start, and if you use that you can start welding without tapping the electrode onto the metal. The spark automatically jumps through the air and an electrical connection is made and the welding starts.
If you dont have high frequency start you need to tap the electrode to get a spark and get the welding going (like stick or arc welding). Maybe this is what HF stands for?
Crossing my fingers im right! Ill see what the pro's say after my post....
Erik
Old 09-20-2007, 04:30 AM
i just managed to convert my mobile videos to .avi hope this benefits someone.
not good quality videos but well gives the idea.
Old 09-20-2007, 04:00 PM
can someone tell me how to calculate the duty cycle of the plasma cutter? i dont understand what to set when trying to cut a door that Sheetcam says it will take 25 minutes on 5 mm plate when the duty cycle says 40% or 60% ? will that mean it will stop after 4 or 6 minutes and to do then?
thanks
Old 09-20-2007, 04:34 PM
thanks
Old 09-21-2007, 07:05 PM
Torchhead is on a distinguished road
DZstar: Duty cycle is one of those "loose" parameters. 40% Duty means you can cut 40% then you have to wait 60% of the period for it to recover. But 40% of what you ask!. Well, until it stops (. It's a function of heat. The power electronics get hotter the longer you cut. If you could wrap them in flowing ice water you could get 100% duty cycle. If the ambient temp is high your period will be shorter (i.e. it will get hotter faster and then it will stop faster and then you have to wait the 60% cool off period.
Put more airflow on the power components and it runs longer and cools quicker.
As you can guess there is no accurate way to predict the actual length of cut time you can get before it stops.
25 minutes!!! What in the wide world of sports are you cutting....an image of the Last Supper? If you have lots of objects you can break them into units and let the machine "rest" at intervals.
I have never had one job that lasted more than 7 to 10 minutes (and even that was not continuous cutting) but I don't cut much detailed (small pieces or cutouts) in 5 mm plate.
I can tell you the numbers (unlike the listed cutting thickness ,which is overstated by a lot) for duty cycles are conservative. It takes into account things like continuous cutting and high ambient temps.
Buy a bigger machine and the times go up. Add better cooling and the times go up. A bigger machine also means faster feedrates so less time to cut the same piece.
Also remember that the SheetCam estimate is total time and includes Z up and down while not cutting and rapids. Anytime the torch is off it is cooling down.
  #11   Ban this user!
Old 09-21-2007, 07:16 PM
Erik
HF does indeed stand for High Frequency. Since plasma is basically burning air it occurs at high temps. The temp of a plasma flame is roughly 30,000 degrees. You can start the porcess one of two ways: Pass a "spark" of high frequency current and ignite the air of use a manual contack "arc" from touching the tip and withdrawing it quickly.
The HF approach works but causes a lot of RF noise during the process. The touch arc method is less noisey but useless for automated control.
The Hypertherm and TD units (some models) use a contact start but it occurs inside the tip. The electrode is spring mounted and with no air flowing its down in contact with the tip. When you fire, the current starts to flow and the air turns on and blows the electrode up and away from the tip and creates an arc start plasma event. That method is limited to units of 100 A or less but does work to reduce noise.
The really cheap units force you (the operator) to be the arc start by touching the tip....not good for CNC or machine cutting.
Tom Caudle
www.CandCNC.com
  #12   Ban this user!
Old 09-22-2007, 04:45 AM
Torchhead,
Thank you for the information,
I got the 25 minutes from Sheetcam estimation for cutting a 1 meter by 2 meters artwork tht I bought from ironshadow (it is a door). i just ran it again on another art work and it gave 18 minutes.
Can you please advise of what Plasma cutter from the ones available locally in Algeria should I buy to be used with my CNC table?
Esab LPH 35
Esab LPH 80
Esab Powercut 650
Esab powercut 875
SAF ZIP 2.0
SAF ZIP 4.0
FIMER 40
Cheap Plasma Cutting Table Jim Stein CNC Plasma and Waterjet Machines 10 09-25-2007 04:26 PM
XY Plasma cutting table design plans? Rich05 Plasma, EDM and other similar machine Project Log 4 08-17-2007 10:18 AM
6.5m X 2.5m CNC plasma cutting table rugludallur CNC Plasma and Waterjet Machines 3 11-16-2006 12:53 AM
plasma table welderman CNC Plasma and Waterjet Machines 2 04-01-2006 11:32 AM
cnc plasma table chiliuno CNC Plasma and Waterjet Machines 7 04-04-2005 09:36 PM
