Old 09-11-2007, 09:44 PM
bumbalow is on a distinguished road
Help!!!! Practical CNC acting funny!!!
Hello all,
I need help in a bad way. I have practical cnc machine with a hypotherm 1000.
The problem:
When I try and move the z-axis down on the soft keys or the page down the z-axis raises. When I change to joystick mode it will move fine.
We checked the cable and it is fine. Any quick ideas? I have a rather large project that is slipping away unless I get it cut.
Sorry so vague.
Thanks in advance.
Old 09-11-2007, 10:38 PM
SORCHEROR is on a distinguished road
im really not familiar with your machine and software to control it,but could it be possible that the keys got changed or reasigned so to speak,in mach you can change the keys,just a thought,is there a parameter page or setup page for the keys,check it out first,good luck
Old 09-13-2007, 07:46 AM
cut more is on a distinguished road
bumbalow,
Hello,
In the wincnc settings there is a place to change the direction of the z but if it goes the right way with the "pendant" then something sounds strange.
Do you have the automatic torch-height control?
Cutmore
Old 09-13-2007, 09:54 AM
I have the practical cnc athc.
Old 09-13-2007, 09:58 AM
can you tell me a little more about what is not working right so I might be able tohelp?
Cutmore
Old 09-13-2007, 10:04 AM
In athc or software mode, when you push the pagedown button it will raise the z-axis, when you push page up it will raise the z-axis.
In joystick mode it works fine and I can raise and lower the z-axis with no problem.
I checked the cables; no problem, I replaced the chips on the z-axis board.
(the 555 and the 4093b)
Any ideas???
Old 09-13-2007, 10:10 AM
Is this something new or has it always been that way?
In the wincnc.ini file you can change things like direction of motors but if it works different ways for joystick vs. page-up/page-dwn that is strange. I think you can re-map the keys also in the wincnc.ini file.
Do you have the manual for wincnc?
If not you can download it on line. just search wincnc, I think the company is microsystems.
cutmore
Old 09-13-2007, 10:13 AM
It just started acting crazy a three weeks ago. I will go through he ini. file stuff and see if there is something wrong there.
Old 09-13-2007, 10:21 AM
Do you use it for routing too? I could see that being a real problem.
In the ini file you can set things like your start stop delay. so if you want to just import a dxf file and cut, your plasma pierce time and end delay will be pre-set which is nice.
How old is yours? Mine is ~ 3years old with steppers and I do routing and plasma with mine all the time. Also with the hypertherm 1000.
Cutmore
Maxnc acting up! abomb55076 Servo Motors and Drives 0 07-31-2006 06:04 PM
Stepper acting funny. Smackre General Electronics Discussion 1 07-13-2006 09:59 PM
Stepper motor acting weird. Help! astro Stepper Motors and Drives 7 05-28-2006 11:18 AM
Help Needed! Stepper motor acting up... nuplowboy Stepper Motors and Drives 1 10-02-2005 02:03 PM
Funny motomitch1 CNCzone Club House 8 01-27-2004 05:01 AM
