Old 08-30-2007, 02:03 AM
bearracecars is on a distinguished road
pierce for center of hole
whats best way to just get a pierce for a center of a hole?
i'm using autocad,sheetcam, mach 3
thanks
bear
Old 08-31-2007, 11:35 PM
Jcar is on a distinguished road
In Autocad, create a "point" at the center of the hole. In Sheetcam, select "Use points for drilling" in the drawing options pop-up window, when opening the dxf file.
You'll have to put the points and circles on different layers, or exclude the circles from the dxf file. If not Sheetcam will pierce the point and then cut the hole.
Old 08-31-2007, 11:46 PM
thanks i will give it a try!
bear
pierce delay in Mach 2 ? Redline CNC Plasma and Waterjet Machines 2 11-13-2011 07:58 AM
finding center of a hole BeerFizz Mach Mill 1 06-14-2007 08:17 PM
Pierce Delay And Plunge Rate DISCONNECTED CNC Plasma and Waterjet Machines 3 01-29-2007 09:48 PM
taft pierce surface grinder problem metalhack General Metal Working Machines 0 11-29-2006 03:19 PM
Drilling a hole in the center of a bolt / newby question stickben Mechanical Calculations/Engineering Design 1 04-30-2006 12:07 PM
