Old 08-27-2007, 12:25 AM
zeoncomp is on a distinguished road
New plasma table with water bed questions ...
I started buiding a plasma table ... no plans, just a lot of passion .... I have a question: How deep the water have to be on the water table? It seems that I can't find that answer anywhere .... Also ... where is the best place where i can buy some linear rails ? Thank you
Old 08-28-2007, 11:18 AM
I am stuck at this stage ... I cannot continue until I know exactly how to proceed with the water table .... can someone please help ?
Old 08-28-2007, 12:01 PM
Jcar is on a distinguished road
My water table has about 3 to 3.5 inches of water beneath the sheet being cut. It works very well.
Here's a picture.
http://www.cnczone.com/gallery/data/...m/DSC_3566.jpg
Old 08-28-2007, 02:30 PM
Thank you .... I can go THE MOST 4 inches. I was just wondering if this was enough. For sure I don;t want to "cut thru" - that will not be funny.
Did you cut AL with it yet?
Old 08-28-2007, 03:24 PM
That is a VERY nice looking table. Where did you buy all the parts for .... did you build the Z axle support or got the whole kit ?
Old 08-28-2007, 05:37 PM
scrambled is on a distinguished road
Zeoncomp-The table that I am building ranges from 4 to 6 inches for the height of the water. I wish I could tell you how great it works, but I can't. (I am still building it) I purchased the linear rails from Rick Hoback at Superior Bearings. He has done everything that he has said he was going to do and more.If you need a link to superior bearing let me know and I will post it once I get home.Steve
Old 08-28-2007, 06:45 PM
Thank you
Old 08-28-2007, 10:35 PM
Weldtutor's Avatar
Weldtutor is on a distinguished road
Arrow Water Table Info.
Hi zeoncomp & welcome to CNC Zone.
Click on this LINK & it will take you to my build log with some pictures, information & a drawing to help you with your water table questions. See posts #161 164 166 & 176.
The depth of water is 4" maximum & I keep the water anywhere from just touching the underside of the material being cut, to 1/2" below the material.
Old 08-29-2007, 12:41 AM
zeoncomp,
4 inches of water depth will be more than enough, assuming your not using a 200 amp plasma machine. The tops of my slat "hangers" are only 1.5 inches below the water surface and show no signs of erosion. I'm using a 60 amp Hypertherm Powermax 1000.
As for my machine, thanks. The entire machine was built from scratch. I'm planning on doing a post about it's construction sometime this week, as it is a recent build.
I have yet to cut aluminum on the water table. I'm still pondering it. Hypertherm says it's a no-no due to hydrogen gas build-up. Thermal Dynamics says it O.K. as long as there's some space between the sheet and the water's surface, and you have bubble agitators in your tank.
Old 08-30-2007, 01:59 AM
bearracecars is on a distinguished road
jcar
nice table i saw the pics in your other posts. whats the bubble agitators that thermal dynamics talked about? my table is similiar in design to yours with the compressed air to raise and lower. fill and empty are opposite corners from each other. i have yet to cut aluminum with the plasma because of the hydrogen build up. my fear was getting it in to the air chamber. hence the reason for a cross flow on the air. i've just been cutting it with a router. i can cut 3/16 single pass with it though, but would like to be able to use the plasma also on alum.
bear
  #11   Ban this user!
Old 08-30-2007, 01:14 PM
Bearracecars,
After reading through the PDF files, I've apparently mixed the two companies up. The agitators were in a PDF that I found on Hypertherm's site. Here's a link. https://www.hypertherm.com/library/f...)/800270r1.pdf About 2/3 of the way through the document you'll find a section titled "Aeration Manifold For Cutting Aluminum With Plasma".
I wish I had thought of installing my input and exhaust air valves on opposite ends of the tank. Smart thinking.
  #12   Ban this user!
Old 08-31-2007, 04:59 PM
Ok ... so I am getting to the point where I have to choose what motors should I use. I think that PlazPak-3 from candcnc.com is very nice .... but maybe I don't need that much. Maybe steppers are just fine. I don;t plan on doing anything with the router in the near future but it can be a posibility. Now I'm thingking - If I'll buy it - might as well but the most complete system - right? Now, are there any differences in the way of building the table if using the servos vs. steppers ?
Also, is this going to work with a servo : http://www.modularcnc.com/linear_slides ?
I am still looking for linear slides (need 2x80" and 1x59") and rack and pinion combination for the 3 axis.
Any sugestion will be appreciated. Thank you
Water Table Rust Questions... hotrodkid CNC Plasma and Waterjet Machines 41 10-24-2008 12:58 PM
Plasma+water table on casters? DeviousMW CNC Plasma and Waterjet Machines 1 05-05-2007 12:51 AM
Water transfer techniques for water table? Knut CNC Plasma and Waterjet Machines 3 02-02-2007 10:52 AM
plasma or water jet??? hutch82 CNC Plasma and Waterjet Machines 8 01-29-2007 09:40 PM
plasma water tank snaggletto CNC Plasma and Waterjet Machines 41 06-17-2006 08:04 AM
