  #13   Ban this user!
Old 01-17-2011, 06:14 PM
jimcolt is on a distinguished road
Hypertherm Plasma systems are rated conservatively for piercing....and each system is a bit different depending on power level and torch design. Here are some rules:
Air Plasma with height control system:
Powermax45 1/2" pierce
Powermax65 5/8" pierce
Powermax85 3/4" pierce
Powermax1650 7/8" pierce
Oxygen Industrial Plasma
HSD130 1" pierce
HT2000 1.5" pierce
HPR130 1" pierce
HPR260 1.5" pierce
HPR400 2" pierce
HPR800 up to 4" pierce on stainless and aluminum
Time for piercing.....approximately 1 second per inch of thickness.
Jim Colt Hypertherm
Originally Posted by xt300301nut View Post
What is the model of the plasma? What per the torch manual is the piercing capacity of the torch. There are very few plasmas rated to pierce above 1" material. Are you able to do "running pierce"? This allows the torch to move away from the molten puddle caused by the pierce. Are you using auto height. Typically auto-height is shut off during pierces of thicker materials and manual height control is required by the operator.
  #14   Ban this user!
Old 01-18-2011, 11:29 AM
m230042 is on a distinguished road
To make the servoed cutting oxygen regulator, we used a separate pilot regulator, and made a replacement "dome" top to replace the normal tee handled spring pressure part of the oxygen regulator. The pre-regulator was set to the desired pressure, and its output taken over to the servoed regulator. A needle valve was placed in the line conveying the pre reg pressure to the dome to essentially delay the pressure buildup and thus the final cut oxygen pressure.
This will work only if there is not a torch select solinoid on the cut oxygen line. If so then a means of blowing down the manifold to 0 psi is needed before it will ramp up again.
Koike puts the cut o2 solinoids on top of the torch as to reduce the pause time after cutting o2 is turned off and the move to the next part. Otherwise you have to delay at the end of the cut to allow the manifold to bleed through the tip. if you try and move the torch to the next pierce it will nick the part as the end of the cut is still at kindeling temp.
  #15   Ban this user!
Old 01-18-2011, 11:54 AM
WSS's Avatar
WSS WSS is offline
WSS is on a distinguished road
Yes, a dump of the dome pressure is needed to "reset". Putting a valve close to the torch does help with postflow quite a bit.
WSS
www.metaltechus.com
heavy gantry drafterman JGRO Router Table Design 6 11-07-2007 10:59 AM
Aluminum: flat, bar, sheet, plate, tooling plate?????????? Dan S DIY-CNC Router Table Machines 12 06-28-2007 12:48 AM
Heavy vice lifting Pat2000 Safety Zone 26 03-16-2007 12:10 PM
looking for a Heavy duty CNC Lathe hydrospin01 General Metal Working Machines 9 03-02-2007 01:21 PM
electronics boards piercing machine shreifali Industrial Hobbies (Support forum) 11 02-19-2007 05:23 PM
