  #25   Ban this user!
Old 01-16-2011, 03:01 PM
m230042 is on a distinguished road
Originally Posted by linatrol god View Post
The floating head is a pneumatic type torch hieght control, you set the height and it keeps itself at that height by rolling on balls across the plate and is held in place by the air pressure, usually used for thinner gauge.
The expensive height control would be best if you are cutting heavier gauge material, it will the set the voltage of the arc, monitor it and adjust the torch height to keep the voltage constant, therefore keeping the torch height steady.
Cal ...I assume.
The weight of the torch plus lifter assembly plays hell on thin gauge plate as it rolls over the cutting slats. sometimes enough to crimp the sheet leaving dimples all over it as the balls roll across the slats. It also has a tendency to move the sheet around. If the sheet is clamped in place, there are no drop parts within 3 inches of your cut path and the steel is thick enough to support the weight the the roller ball floating head is dandy. Otherwise go with the auto height control. The one qouted only has a 3 inch stroke Drive and control is contained with in the motor and was a bear to get to work right when we first played with it...but it works fine after rodney got finished with it.
Marv
  #26   Ban this user!
Old 01-16-2011, 03:12 PM
Originally Posted by Al_The_Man View Post
Incidentally I just recalled that Acroloop had a simple feature that would prevent that had it been implemented.
The card had a relay output contact that would detect if the card malfunctioned or the controller power went down, in their documentaion they suggested using this at the start of the E-Stop string, therefore dropping all control power and the drives off.
When I implemented the card in a system I would always use this feature.
Those were some bad times for engineering back then. When the price war started they tried to do many things and unfortunitly most of them wrong.
After some shake up in engineering they got their crap together and came up with the milinium line that is for all pratical purpuses ...perfect. Everything engineering did had to be approved by the Field techs. They even stole our best one!!
I installed the second mastergraph milinium in Va. after two years of operation it had lost only .002 in the cross axis X and .006 in the Y. Still running strong after 10 + years.
Linatrol tracer set up on Koike Plasma arlenw CNC Plasma and Waterjet Machines 28 08-16-2011 10:43 AM
Koike D10 Troubleshooting kevin@work CNC Plasma and Waterjet Machines 3 09-23-2005 03:37 PM
