Old 07-09-2007, 06:52 PM
jpmassey is on a distinguished road
What is the best plasma cutter
I'm considering purchasing a new plasma cutter, I have a miller spectrum 500 and it doesn't seem to like my electronics much. Also, the nozzles produce a kerf of about .125, which doesn't allow for good detail work.
I'm looking at the major manufacturers (hypertherm, thermal dynamics, miller...). My main concern is kerf width on small stuff (<3/16). (I've been looking at the hypertherm fine cut consumables, but haven't found an actual kerf width number.) I also want to be able to cut the occasional 1/2" plate as well. Right now I'm leaning towards the hypertherm 1250 w/ machine torch.
Any advice?
Old 07-10-2007, 12:21 AM
Torchhead is on a distinguished road
Fine cut kerf width on 16ga is about .035. Slightly bigger on 14Ga. I cut 10Ga and up to 1/4" with a 40A tip and it has about .043. My 60A tip gives about .056 on 10g and .065 on 1/4"
What height and tip volts are you using on the 500? I used to get smaller than
.125 kerf width with new tips. I found a source of really cheap tips and I changed them every 25 to 50 pierces. I had to use good grounding techniques but my 500 ran with a PC and THC electronics about 6 ft away.
The 500 is truely a wretched machine for CNC cutting but I cut miles of decorative steel with mine. Once I got a Hypertherm1000 I could not believe how much better and faster it cut! I think working and making the 500 work made me a much better plasma "Dude" than if I had just started out with the best first.
Old 07-10-2007, 01:51 AM
Mongkol is on a distinguished road
plasma machine.
Hi Torchhead,
I have some question to ask you.
1) I am little puzzled with GA unit as you refer. What does it mean?
2) It's possible or not.Could you please advise me for sources which sell tips to release kerf width smaller than? please advise.
3) THC system? It's necessory to use with plasma cnc or not ? I found some machines that did not have this system.
Cheers,
Mongkol
Old 07-10-2007, 12:33 PM
Robin Hewitt is on a distinguished road
I've never quite figured out why sheet metal thickness should be measured in standard wire gauge and then called gauge instead of SWG. It is a peculiar standard like those whacky letter and number drills. Guess it's a history thing
6 swg 0.192"
10 swg 0.128"
12 swg 0.092"
16 swg 0.064
18 swg 0.048"
20 swg 0.036"
22 swg 0.028"
24 swg 0.022"
Old 07-12-2007, 05:12 AM
PlasmaGuy's Avatar
PlasmaGuy is on a distinguished road
I recommend Hypertherm. I own a 1650 G3 and have runs it hard for 4 plus years. Hypertherm produces only plasma equipment. Period. Their customer support is top-shelf too, not that it is required very often.
Good luck,
Tom
Old 07-13-2007, 01:47 AM
I've tried heights of .05 to .2 with not alot of difference. I can't measure the volts since the electronics dies when the torch fires.
Old 07-16-2007, 11:24 PM
bearracecars is on a distinguished road
hi tom
whats your "source for cheap tips?
thanks
bear
Old 07-17-2007, 12:01 AM
Also, can anyone recommend a good place to buy hypertherm units? The local places are pretty high, and I'd have to pay tax as well.
Old 07-17-2007, 03:38 AM
PlasmaGuy's Avatar
Gentlemen,
This is a company that I buy my consumables from to keep my local vendor honest.
http://hypermax.3dcartstores.com/index.html
They have "free freight" on complete machines too, plus you save sales tax if purchased outside you state.
Luck,
Tom
Old 07-17-2007, 03:02 PM
DSL PWR is on a distinguished road
You get what you pay for...
Also check the price on Miller, Lincoln, and Esab. I found the price on the Hypertherm to be less than the others when I bought mine.
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 07-17-2007, 04:09 PM
Gold Member
Bobbyr70 is on a distinguished road
Lean like you are headed, Hypertherm is a very good unit I purchased mine from an ebayer I got a much better deal than locally and it shipped in 3 days for free. Call 1-866-360-WELD Tell them Bob From Oregon Refered you.
  #12   Ban this user!
Old 07-19-2007, 02:07 PM
xjdubber is on a distinguished road
thermacut sels great consumables
Plasma Cutter mikie CNC Plasma and Waterjet Machines 7 03-22-2011 07:56 AM
Ghetto plasma cutter! ty1295 Plasma, EDM and other similar machine Project Log 12 03-02-2008 08:13 PM
Air or Gas plasma cutter? KKamel CNC Plasma and Waterjet Machines 1 09-02-2006 11:59 AM
Artwork for Plasma Cutter cnc? Crayola CNC Plasma and Waterjet Machines 1 06-14-2006 10:44 AM
plasma cutter with deskam guy CNC Plasma and Waterjet Machines 0 02-14-2005 04:34 PM
