#15
Attached is a ZIP file containing 4 files that you can use to mill Cable Chains out of PVC. These files produce the commercial looking cable chains that you can buy from several sources. Very nicely done! The files are all in CamBam format. You can load them into CamBam and produce GCode, and you are ready to go. If you do not have CamBam, you can download a trial copy that will allow you to do 40 operations before the trial expires. If it would help, I can make .nc or .tap files and post there here as well. George |
#16
| I just bought two of these for 40usd (£26) each, they come with ends. eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices WSS
__________________ www.metaltechus.com Last edited by WSS; 12-16-2011 at 08:35 PM. |
#17
Alternatively, if you have lots of wires, look at the corrugated plastic hose for sump pumps with a 1-1/4" ID.
#18
| The ribbed/slit wiring harness tubes/sleeves used in cars/trucks. I found several vendors selling it in 50' to 100' lengths and from a 1/2" to over 2" ID's. The sizes I've used: 5/8" -- 3/4" -- 1" The fact that they are use on and around the heat of engines means they will work great on Plasma tables. To attach it I just make a "T" out of 16/18 ga. -- two small holes in the top of the "T" and then as many zip ties around the leg of the "T" as needed. (A few drops of Super Glue wouldn't hurt on the bigger sleeves.) Grandpa Bill
__________________ "Inventor" A "True" machinist loves it when they say: "That can't be Made"!!! |
#19
![]() Quick, cheap, easy, and it doesn't require the gantry to have to drag around all of the extra weight of a wire track. I have a small steel cable routed from the Z up to the trolley above, and all of the wires tied to that steel cable.....so all of the pulling is on the steel cable and not the wires. I works great...have not had a single issue with it. |
| Flexible Coolant nozzle | impact | General Metal Working Machines | 9 | 07-08-2009 06:02 AM |
| Flexible coupling | Buzz9075 | DIY-CNC Router Table Machines | 1 | 01-12-2007 11:57 AM |
| Fairly Cheap Flexible Software | Scra99tch | General CNC (Mill and Lathe) Control Software (NC) | 1 | 08-21-2006 08:27 AM |
| Flexible Shaft Couplings; where to buy? | boyvox | DIY-CNC Router Table Machines | 17 | 04-13-2006 03:37 PM |
| source for flexible raceway | owhite | DIY-CNC Router Table Machines | 6 | 01-20-2004 09:21 AM |
