#13
| Not a crappy machine at all. I love Hypertherm ![]() It is a bit small to expect clean and accurate bolt holes out of 1/4 plate. The resulting beveled edge that is inherant to the plasma process will surprise and frustrate you when you go to insert a bolt in your 1/2" hole, and find it fits in the top of the hole, but the bottom of the hole is .45" instead of .5 That plasma will also have a very light duty cycle when asked to cut 1/4 plate, and it will not cut it in a hurry. Expect your cut speed on 1/4 plate to be in the 20-25 inch/min range. You will find a higher amperage plasma will aid you in cleaner bolt holes, and faster cut speeds. What you are trying to do will work, and is more than possible, but will have its' limitations. I am guessing if you do much chassis fab, you will be wanting to upgrade within a couple of weeks, but that is just my guess. Hope that makes it a bit clearer...
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) "If the women don't find you handsome, they should at least find you handy" -RedGreen show. |
#15
| Well, if you had two smaller steppers, they could theoretically be wired to the same driver, if you had a big enough driver. I do not recommend this. Use one driver per motor, and either connect them both to the same output from the breakout board, or slave them inside Mach, if you are using Mach.
#17
| This two motor idea seems needlessly complicated. It really is very simple, perhaps we are not explaining it very well |
#19
| You should not feel retarded, just uninformed. I have not been able to get to my shop to take a decent picture of how it all goes together, but will try to tomorrow, if I feel better. Two motors are generally not neccesary, but will work. To save money and time, you just use one motor on one side , with a shaft that goes across the table that has your driven gears, one on each side. When the motor rotates, it rotates that shaft, spinning gears on both sides of the table, acting like two motors.
#21
| look at posting # 21 (link below) for pictures of the shaft system described above (it is of another members machine) you may want to read the whole thread, its got some great info and pictures http://www.cnczone.com/forums/showth...t=32058&page=2 |
#22
| Dual drive systems (motor on each side), often called "slaving" are not overly complicated and offer certain advantages (double the drive torque, auto squaring) and don't have long drive shafts across the gantry. I have a two motor dual drive gantry that I have been using for almost 5 years in production cutting and the servos are tiny compared to today's standards. Both systems work and both are used with success but choose the one that is easier for you to build. If you have a way to turn a precision shaft with bearings than that might be the best. If you don't mind buying an extra motor and motor drive card then the dual drive system will serve you well. You cannot and should not hook two motors to one driver card. In servos it would be a nightmare. With steppers it would cause resonance problems and negate the smoothness from microstepping. tomCAUDLE www.CandCNC.com BOB's Digital THC Complete Electronic Packages Stepper & Servo Systems Hand Controllers |
| New To The Whole Idea | EvilSmirk | Benchtop Machines | 11 | 11-01-2006 10:34 AM |
| My idea of a spindle design | Guldberg | Mechanical Calculations/Engineering Design | 51 | 10-07-2006 05:48 PM |
| New CNC idea | Zumba | CNCzone Club House | 14 | 03-01-2006 01:08 AM |
| EDM idea | DragnsBane | CNC Plasma and Waterjet Machines | 5 | 02-23-2005 05:50 AM |
| New idea! | smitty | OneCNC | 3 | 08-26-2003 10:45 AM |
