Old 05-05-2007, 12:38 AM
DeviousMW is on a distinguished road
Plasma+water table on casters?
I have 6 1500lb rated castors I was thinking about putting on the bottom of the table to make it slightly mobile... basically roll from one bay of the garage to the other. I see a lot of folks using leveling feet or just steel legs. Is there some big disadvantage to having it on castors? Its gonna be a dam heavy table so the movement of the Y axis shouldnt really move the table around.
I need your wisdom..
Thanks,
DeviousMW
Old 05-05-2007, 12:51 AM
massajamesb's Avatar
massajamesb is on a distinguished road
When you have your machine on casters, the inertia of the gantry moving around can shift the table on the casters, at least during rapid movements of a heavy gantry. This can also shift your workpiece.
Casters are not a bad thing, but make sure you can retract them or lift the table off the casters.
"If the women don't find you handsome, they should at least find you handy"
-RedGreen show.
Water transfer techniques for water table? Knut CNC Plasma and Waterjet Machines 3 02-02-2007 10:52 AM
plasma or water jet??? hutch82 CNC Plasma and Waterjet Machines 8 01-29-2007 09:40 PM
Plasma/water/lazer cutting ty1295 Employment Opportunity 4 10-14-2006 08:36 PM
plasma water tank snaggletto CNC Plasma and Waterjet Machines 41 06-17-2006 08:04 AM
NEED 1/4" plate cut via plasma/water/etc. ty1295 Employment Opportunity 3 04-20-2006 09:29 AM
