This may be a dumb question, but at least it is a simple one. I think I remember reading somewhere in the past that the higher the amperage on the plasma torch (larger capacity, not just a higher setting) the more narrow the taper is. That is to say if you use a 100AMP torch you should expect less taper than if you used a 40AMP Torch for the same cut (both set to MFG reccomended settings for the same thickness material). Is this true? I would figure that it would be the same regardless of your machines capacity, if the cuts are in the same materials and within the cut thickness capacity of both machines. A little clarification from someone with more experience than I would be great. Thanks Doug |
| 2.5 amps per phase drive - 2.8 amps per phase bipolar motor ... | kochevnik | Stepper Motors and Drives | 6 | 10-22-2006 10:48 PM |
| Crazy inventor seeks wire EDM shop for long term relationship... | InspirationTool | Employment Opportunity | 0 | 07-27-2006 09:49 AM |
| gas pipe & linear bearing dimensions relationship | zoltan | Linear and Rotary Motion | 6 | 06-13-2005 03:12 PM |
| The relationship of limit switches to home switches. | MikeAber | General Electronics Discussion | 4 | 11-04-2004 01:28 PM |
| Howto find input amps, from output amps on transformer? | sendkeys | General Electronics Discussion | 7 | 07-14-2004 07:13 PM |
