Old 04-03-2007, 08:04 AM
LeeWay's Avatar
LeeWay is on a distinguished road
Plasma cutting metals other than steel.
I realize this is a really ignorant question. I have actually done many searches trying to find an answer. I have owned several different types of welders. I used to own a wire feed welder that could weld aluminum using different wire and (argon?) gas. I never actually used it for anything but steel.
Do I need a gas other than compressed air to plasma cut aluminum?
My router does pretty well cutting thin aluminum, but I was just curious. Also if there are other gases needed to cut other metals, where would I find something that tells me what gas for what metal?
I like some of the things (artwork) I've seen made from copper. I guess they are flame kissed afterward with an OA or OP torch to get the coloring.
Lee
Old 04-03-2007, 10:28 AM
Mike@Torchmate is on a distinguished road
You can cut aluminum, copper, bronze, and brass as well with plasma.
Some people will use a gas mixture with aluminum instead of just compressed air to get a better cut quality as aluminum can have a pretty bad cut quality if not done properly.
Mike @ Torchmate.com | www.Torchmate.com
Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
Old 04-03-2007, 01:25 PM
LeeWay's Avatar
Thanks, Mike.
I thought that was the case, but never saw it nailed up to read anywhere.
Lee
Old 04-05-2007, 12:07 AM
millman52's Avatar
millman52 is on a distinguished road
I have heard of inert gasses (nitrogen maybe) mentioned. But I think the topic for the discussion was about keeping moisture & oil away from plasma.
If it works.....Don't fix it!
Basic plasma troubleshooting - 1/4" steel meerkatguy CNC Plasma and Waterjet Machines 3 01-20-2007 01:23 PM
Speeds for cutting metals relating to pulley size? ZipSnipe Mechanical Calculations/Engineering Design 2 06-15-2006 08:11 PM
Plasma cutter for 3mm mild steel DEEDEE CNC Plasma and Waterjet Machines 5 01-19-2006 05:25 PM
Cutting stainless steel andy_ck87028 Mechanical Calculations/Engineering Design 6 09-25-2005 05:14 PM
cnc plasma or oxy for 5/8" steel tltaylor CNC Plasma and Waterjet Machines 3 01-06-2005 11:50 PM
