So I am considering dropping $400 bucks on some rack from stdsteel.com. I am planning on buying (2) 4ft and (3) 6ft sections of 20 PA, 20 Deg pitch, 1/2 face by 1/2 wide steel gear rack. The 4ft and two of the 6ft sections would be machined to matchup by the company to form two 10ft lengths. All the rack would be drilled and tapped by them with 3/16" holes 1" from each end and spaced evenly across the rack with no more then 12" between holes. The holes would be coutersunk so flathead machine screws could be used. What do you think? Good buy? I want to make the right choices when building this table, as the wrong ones cost a lot of money Thanks, Mike |
| It is not completely necessary to machine-match the ends, if the ends are cut just short of the bottom of the trough, a small gap can exist because the gear does not touch the bottom, a short piece is used to straddle two lengths while fixing to keep the pitch identical, I usually use counter-sunk allen head, why the tapped holes by the way, if you are counter-sinking? Al.
Thanks, Mike |
| Before you bite off on the 20 pitch rack make sure there are off-the-shelf pinion gears to match. My catalogs have lots of choices for 24 pitch but 20 seems to be less plentiful. Maybe I am just looking in the wrong place.......... Tom Caudle www.CandCNC.com |
| Boston Gear carry them with 1/2" face from 12 to 200 teeth. Al.
I just called them up.. they recommended a 30 tooth 1/2" face 20 deg pitch 1/2" bore gear based on the torque it needs to handle... supposedly about $20 each from mcmastercarr (a distributor). This would be for my X axis with a max 100lb gantry.. for the Y axis I am thinking maybe a smaller gear since it will be driving a much lighter load despite having the same torque (Got a deal on those 640 oz steppers). Mike |
| Sir, A good source of gear rack is http://www.stdsteel.com/gear.htm They have in stock 1/2 x 1/2 x 6 ft rack, 20 DP, 20 degree PA for a price of $23.20 each in quantities of (2). The pricing is about a year old. Earlier comments about fitting rack end-to-end were correct. And as to drilling, make clearance holes for #10 screws and do-it-yourself. If you are building a machine, mounting the rack is easy for you to do. Regarding pinions, for 20 degree gearing, 18 teeth is the min number to avoid undercutting; for 14 1/2 degree rack the min number is 32 teeth to avoid undercutting. Boston gear lists 20 DP, 20 degree pinions, steel, which should be OK. If you spring load your drive pinion into the rack, you need to provide sufficient force to overcome the separating force from 20 degree pressure angle; this would be [Drive Force x Tan 20 degrees]. If the drive force is to be 50# max, spring force = 50 x .3639 = 18# spring load. Regards, Jack C. |
#10
I am paying $80 for this segment with the drilling. chop saw, a welder, and drill press. I am sure the factory can make much more precise holes vs me.. I will have enough dilling to do when mounting it to the table.
How do you caculate the drive force? Thanks, Mike |
| If you had the choice, which SS would you choose? | PEU | General Metalwork Discussion | 25 | 10-06-2006 07:19 AM |
| Is the Xylotex a Good Choice | bill south | Xylotex | 2 | 07-23-2006 11:50 AM |
| VFD choice | zcases | Phase Converters and VFD | 0 | 09-30-2005 08:59 AM |
| Stepper choice | JW Peters | Stepper Motors and Drives | 0 | 05-26-2005 09:09 PM |
| software choice | mackenzie | General CNC (Mill and Lathe) Control Software (NC) | 0 | 11-24-2004 09:46 PM |
