Old 03-22-2007, 12:57 AM
deejayehn is on a distinguished road
Hello All... I'm A Total Newbie 2 The CNC Stuff.
Where would I go to get the best crash course on CNC plasma?
I'm an artist that really wants to get one of these machines.
What machine is the best value for your money?
What is the best plasma cutter for your money?
Thanks ahead of time for all of your tips,
DeeJay
Old 03-22-2007, 09:48 AM
blackhollowmfg's Avatar
blackhollowmfg is on a distinguished road
deejayehn - You have came to the right place! I too had never even seen a CNC plasma before I decided that I wanted one. Not knowing anything about them, I went with a Torchmate 1 kit that you build yourself. They provide all the brackets and electronics (motors, signal generator, cables, etc.) and can supply you with the plasma cutter too (I use a Cutmaster 101), as well as a computer. I went from knowing squat about cnc cutting to building my machine to cutting parts in under 2 months.
If you have the skills, and want to take it on, there are several plans on this forum to build a nice table, and PLENTY of knowledgeable people here to help out with the electronics.
It comes down to how much you can spend and hw soon you need it up and running. Stick around here, you will soon become an addict!
Old 03-22-2007, 01:29 PM
Mike@Torchmate is on a distinguished road
You can check out our website and download our catalog for prices, we have everything ranging from Production based machines to a small 4'x4' table for hobbyists who are just looking to get a simple machine for artwork and such.
Our bolt together kits can be assembled in less then a day as well in case you are not comfortable with welding a table together.
Check us out at www.Torchmate.com
-Mike
Mike @ Torchmate.com | www.Torchmate.com
Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
Old 03-22-2007, 03:22 PM
Torchhead is on a distinguished road
For the electrically/electronic challenged builder that would like a cost effective system that INCLUDES a Digital torch Height control check out out Plazpak Package deals.
http:/www.CandCNC.com/SolutionsMenu.com
All of the wiring and electronics (including limits) are part of the package and every thing is intergrated and tested here prior to shipping. Motors plug in (they are even color coded to help). The mechanics are up to you but there are good plans available on this site.
We use and advocate the MACH3 approach. It in fact ships with our PlazPak products. It's a non-hardware based system. With over 7,000 users and excellent support from the web and from us it makes a very cost effective plasma solution. The MP1000-THC is tied into the toolpath software (MACH) and you can control the THC cutting parameters from the MP1000-THC, MACH screen or from our new 28 function Hand Controller that plugs into the front of any MP1000 series unit.
For decorative cutting (of which we do a lot) the combination of CorelDraw, DXFTool, SheetCAM and MACH3 makes for a plasma cutting solution that I will put up against packages costing many times the low total cost.
If you are from the art side, you have probably used CorelDraw but don't know how good it works as the artwork engine for plasma cutting decorative or signage projects. Join my CandCNCSupport Yahoo group and get access to free CDR Corel clipart samples for plasma. Download the DXFTool from my website and try it free for 30 days. Loads and runs inside CorelDraw 12 or X3. Get a full demo copy from Les at www.Sheetcam.com and use it to setup your plasma specific toolpaths. Help is always available from his Yahoo Group or from me since I use it daily to do plasma (and wood routing).
Tom Caudle
www.CandCNC.com
Old 03-22-2007, 04:39 PM
Is there a decent opportunity to make money with one of these machines?
How are you doing it?
Do you send out a direct mailer out to mailing lists?
Do you just go to trade shows?
Online catalog?
How do you market your "talent"?
Just curious...
Old 03-22-2007, 05:17 PM
massajamesb's Avatar
massajamesb is on a distinguished road
It depends. What do you want to cut? Are you looking to sell metal art? chassis and suspension pieces? Bracketry for metal fabrication shops??
The possibilities are endless when it comes to selling your work. You just have to take the Nike express around town, and find out what people want, and figure out how to sell it to them.
There are a number of homebuilt machines on this site, and quite a few pre-built machines as well. Take a look around and gather some opinions.
"If the women don't find you handsome, they should at least find you handy"
-RedGreen show.
Old 03-22-2007, 05:37 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
deejayehn,
This link might help?
http://www.cnczone.com/forums/showthread.php?t=34674
Old 03-23-2007, 12:23 PM
Perp is on a distinguished road
Tom Caudle
www.CandCNC.com
Just checked out your website for the plazpak electronics setups and i am very impressed. what is the lead time on shipping one of these (plazpak4 for dual x drive)? I plan on placing an order around the first of April.
Also I need to supply a computer, but what else do I need to complete this system and what are your recomendations on the computers specifications. It will only be used for this table and will be new.
Doug
Old 03-23-2007, 01:11 PM
The average time for shipping is currently running about 3 weeks after we receive the order. Each system is built up and fully tested using the actual components we ship (drives, motors, cables, etc).
For MACH I recommend a 1.8GHZ CPU or higher and min 256M Ram. It needs to have a parallel port or an open PCI slot to add in a Parallel Port card. Needs to run XP or WIN2000. I have had good success buying the ECS motherboards from Newegg.com (the 89.00 special) and some matching DDR memory and upgrading an older ATX PC. You don't need a new HD or CD Reader and those cards still have a full communications riser with Parallel and serial plugs!
Don't spread this around but if you place an order before the end of next week for the Plazpak3 or 4, I will throw in a FREE MPG101B Hand Controller. (unadvertised special). Plugs right into the front of the MP1000-THC and gives you most of the setup and run control including being able to adjust the tip volts (cut gap) up and down while cutting and turning on/off the THC or the Anti-Dive options.
Tom Caudle
www.CandCNC.com
Old 03-23-2007, 01:21 PM
Tom, sounds great and you will be hearing from me next week!
Doug
  #11   Ban this user!
Old 03-23-2007, 01:45 PM
Online catalog?
Just curious...
Well, we make money from the steel cutting and at one time it was 100% of our income. I tell you a lot of things that do/don't work:
Don't work: Flea Markets (hard to sell a $100 cutting to person with $10 bucks in thier pocket).
Don't work: Selling precut general designs. The real money is in personalization and custom work.
Don't work: A website alone will only bring in about 20% of what you need to survive (but you still need one)
Does work:A color brochure (even if you print it yourself) helps a lot.
Does work: Find a local independant restaurant(s) and see if you can setup a display in their waiting area and put out brochures (simple 1 page with your website and phone number) in exchange for cutting them some "art" for the restaurant.
Does work: Word of mouth for local customers. Get pictures of everything you cut.
Does work: Offer finishes (powder coat) on pieces. Get setup with a local powder coat shop to do bigger stuff and learn how to do stuff less than 24" yourself.
Don't work: Smaller cuts than about 14" in size. Too much handling and labor for the preceived value.
Don't work: selling through retail gift shops.
REALLY don't work: selling through any consignment agreement.
Sorta Works: Find local gate and fence companies and provide them with a way to buy a really low cost package of samples and free catalogs. Most will look at you like you grew a third head. A couple will see the value. Have wholesale pricing or work out a commission program so they can make money.
Your decorative cutting business will be spotty and seasonal. You will do well around Christmas and poorly in the summer months (even though a lot of the exterior work is being done then)
So there you have some of the things I learned. If you already have contracts with local mfg's and fab shops that could give you job shop business or contract business, then you can build that part of the business but beware that they will beat on you ruthlessly for lower prices and you find yourself working for minumum wage (happens anyway (:_))
Like any other business on the face of the earth it's success will depend on your willingness to stick with it, but to change course when the target moves. Never quit your day job based on a promise of work or one job. Keep your overhead as low as possible the first couple of years. Be honest and straight up with your customers, but be aware they may not be the same with you.
Trust and verify
Tom Caudle
www.CandCNC.com
  #12   Ban this user!
Old 04-02-2007, 12:43 AM
Trust and verify
Tom Caudle
www.CandCNC.com
Thank you for your tips... you must have alot of experience.
Mainly I want to do the art thing. I do have my own designs, and can easily tweak many popular designs so the designs are uniquely mine.
I suppose that if there was a dry spell, I would want to look into doing fill-in projects for income supplementation/cash flow.
I would be very interested in doing custom work for vehicles and custom bikes/choppers as well. Very interested...
Just don't know much about the cnc plasma cutter stuff... even though I went to votech/college for a year doing cad/3d cad in drafting.
Ironic how I'm coming around almost full circle after over 10 years from being away...
I was first introduced to the Plasma Cam dvd. There seems too be alot of negative press around here for it. It looks fairly impressive to me, but I do see the disadvantages of all the comments floating around this forum. The tech support will be a very important issue for me anyways.
Where do you go to learn about the software? I'm totally out of the loop on this one... What is the best software?
What is the best laptop for this type of application?
Mach3 tuning (cuts small stuff fine, but is off on big stuff) jdbaker Mach Software (ArtSoft software) 4 03-15-2007 11:30 AM
Total CAD newbie after some advice wildstallionuk General CAM Discussion 3 10-20-2005 06:07 PM
welding thick stuff to thin stuff - need advice cross6 Welding, Brazing, Soldering, Sealing 5 01-13-2005 01:39 AM
Total Newbie on Taig CNC Mill!! vwgo Taig Mills & Lathes 2 10-17-2004 07:40 PM
Total Newbie question here redbaron General CAM Discussion 4 06-24-2003 02:02 PM
