Old 02-24-2007, 04:29 PM
tyler774 is on a distinguished road
Unhappy Anybody toubleshoot there Powermax 1000?
Hello all
Something stange hapened today, went out to the shop to do some cutting but my machine torch wont fire. Has been working flawlesly for a couple of years so is not related to some sort of set up issue.
Anyways I pluged in the hand torch I have, it fires when the trigers pulled but not when comanded by the CNC. I have a seperate start switch that plugs into the machine interface and it wont cause the torch to fire either.
So dowloaded the Hypertherm service manual and did there plasma start test #8
( involves putting a jumper across the red & white on the machine interface , J19 ), and what do you know the machine torch fires.
Man this confuses me, I'm taking the machine into the dealer on Monday but thought I'd see if anyone out there has had this happen.
Tyler
Old 02-24-2007, 05:58 PM
Weldtutor's Avatar
Weldtutor is on a distinguished road
Troubleshoot this separate wiring & the plug on it & the plasma machine for breaks or discontinuity etc.
If that is OK disconnect the wires for the separate start at the CNC & jump those 2 together. If this fires the torch, it is likely that your CNC controls are not sending the start signal. Perhaps a bad relay.
Old 02-24-2007, 06:17 PM
Thanks Weldtutor
I'm going to give that a try.
Old 02-25-2007, 12:49 PM
Well I 've got a proper diagnosis now.
Seems the plasma cutters fine. I've narrowed the problem to the CNC control not closing the start circuit to activate the torch.
Thanks Weldtutor for helping me with this one.
What got me mixed up is I presumed my start switch had to work, worked before last time I used it. Discovered a wire had come unconected from the plug.
Tyler
Old 02-25-2007, 02:25 PM
Weldtutor's Avatar
That will do it.
Thanks for the report & glad you found the problem.
You should be able to make fire now.
Powermax II cables moto21 Stepper Motors and Drives 3 04-09-2007 03:56 PM
Powermax II Help Bryanpl Stepper Motors and Drives 14 02-21-2007 01:47 PM
Anyone interested in buying a powermax 1000 with machine torch, in vgc? Apples CNC Plasma and Waterjet Machines 1 12-27-2006 02:54 PM
Torch Height Control for PowerMax 1000 barnon Mach Plasma / Laser 2 08-11-2006 11:30 PM
Powermax 2 crow General Electronics Discussion 1 04-02-2004 11:09 PM
