Old 02-11-2007, 04:54 PM
DeviousMW is on a distinguished road
Steel thickness for slats and water tray walls
So I am planning the build for my water table. I have decided to hold the water and slats in a large steel box
(5'x10'x8" deep) which will slip into and be supported by the bottom of the CNC table (4 2"x2" cross slat bottom on a 4"x2" frame). The weight of the water in the box will be 2060 lbs and the slats need to support 686 lbs (weight of a 1/2" thick 4x8 sheet of steel).
What steel thickness would you recommend to create the box and how thick should the slats be. I figure the slats ideally would be 2" wide placed on their sides. Any suggestions for painting/rustproofing this thing? Any non harmful water additives that can stop rusting?
Thanks,
DeviousMW
Old 02-13-2007, 09:01 AM
jcc3inc is on a distinguished road
Water table/slats
Sir,
You could use 11 ga or heavier material for the tank.
As to supporting the workpiece, some make a pair of comb-like slat holders which have the slots cut (for the slats), set at a slight angle, maybe 10 degrees so that the slats always are tipped when the workpiece is loaded, and there is no tendency to teeter back and forth.
The slat holders could be 1/4 or 3/8 inch thick, maybe 8-10 inches high. You might use a large angle iron and cut the "teeth" in it. If you choose to buy the slats from a supplier, they can be 1/8 to 1/4 (or maybe thinner), spaced 4-6 inches. Some guys have the slats sheared from sheet stock. Slats are consumed in the cutting process, and sometimes you can tip them upside down to extend the life before scrapping them.
We used to recommend an additive for cutting tanks, but I don't recall the Chicago area manufacturer. You might call a welding supply distributor, one who deals with cutting machines.
Regards,
Jack C.
Old 02-16-2007, 03:10 PM
Originally Posted by jcc3inc View Post
Sir,
Jack C.
Thanks Jack.. Its difficult to know what strength materials to use without
a lot of expensive trail and error. This is a big help..
DeviousMW
Old 02-17-2007, 04:54 PM
millman52's Avatar
millman52 is on a distinguished road
On my old table I used 1/4" X 2 amgle iron for the burn slats & bolted them in. After they were burned up beyond use I tack welded new 1/4" X 2 strap to them for a second life. After that toss them out & start over. On the new machine I am building I plan on using 1/4" X 3 HR strap placed on edge in the "combs" mentioned by others. What ever you decide, price first. I had planned on using 3/16" X 3 HR for the slats but when I priced material I found the 1/4" to be cheaper than 3/16 or 11 gauge sheared. May be different from your supplier.
If it works.....Don't fix it!
Old 03-15-2007, 03:26 PM
energyforce is on a distinguished road
Why have the water so deep? My table's waterbath is only 1 inches deep at the most. I have not used it yet though.
Coolant tray for X3 oldtool Polls 1 02-10-2011 11:11 AM
water table and support steel weight? Crayola CNC Plasma and Waterjet Machines 1 02-10-2007 10:51 AM
panalized walls & cnc ? ken12939 Commercial CNC Wood Routers 0 01-06-2007 11:45 PM
Steel rectangular/square tubing wall thickness pstockley General Metalwork Discussion 0 01-27-2006 01:56 PM
