Old 02-10-2007, 08:37 AM
riverrat is on a distinguished road
wire edm help
We are looking into purchasing a wire edm.
Unfortunatly we know NOTHING! about them.
Where to start? What machine? What features?
There is one on ebay we are looking at, 1996 mitsubishi
refurbished by mitsubishi in 2002, buy it now for 22,500 (I think)
auto wire feed, 15 degree taper.
Is this a good machine?
thanks is advance
totally clueless
Old 02-10-2007, 06:26 PM
come on guy's, don't leave me hanging like this.
surely someone has some wire edm knowledge
to pass on.
Old 02-10-2007, 06:39 PM
notallhere is on a distinguished road
Not a real experianced guy with them, but we just got a used Japax never seen one before last week. Huge amount of work to clean it all the filters were blown out and the thing looked like it had never seen any maintance in its long life. Something to look at when buying a used any kind of machine.
Do all the manuals come with it or are they missing. Its a big pluss if they do come with it. I have been able to in a week get it cutting, it took alot of reading and time to sit at it and work through all the settings but hey thats what i get paid for.
As far as is the one your looking at a good machine hey cant say, we got ours at a auction and could at least see it up close and personal so we knew what we were getting into.
Good luck!
Just another chip in the pile.
aaron
Old 02-11-2007, 05:09 PM
victorinox76 is on a distinguished road
Wire EDM
Fanuc EDM's I have found to be ultra reliable with great generator codes. The ease of maintenance and cost per hr is great. Just my 2 cents...
Old 02-13-2007, 07:28 AM
roysol is on a distinguished road
What you need in an EDM depends a lot on what type of work you hope to do with it. What are your tolerance requirements, surface finish, work piece sizes, taper angles, production vs tooling, in house vs jobbing, etc.
In general, shops with no EDM experience who buy used machines have a very steep learning curve. If you scan older threads here, and at the couple of other active EDM specific forums, they are full of people who need manuals, technology settings, trouble shooting, programing and applications help.
This is not to discourage you from doing it, just so you go in with your eyes open. For example, if your planning on competing with EDM shops, your 1996 mits will be cutting less than 10 square inches per hour, while the current models will be cutting in the mid 30's.
If you have some more questions, fire away. (You didn't say what model Mits was on Ebay, but I run them now and have in the past, and they are decent machines for production type work that's not too fussy).
Cheers!
Roy Solomon
Old 02-13-2007, 06:21 PM
we have farmed out over $6000.00 in simple edm work
this month alone + or - .0005, 2 dimensional stuff.
from what i understand that kind of accuracy is easy to achieve.
our market is prototype, and very small production runs with
some, but not a lot of competition, quality sells, and we sell it.
another thing, submerged or not?
our understanding on this is on a submerged unit you have to drain and
fill the tank on each part. with a non submerged machine you run a coolant
(deionized water?).
also how do you figure speeds, power, and numerous other values you need
to know?
pretty sure i'm gonna be a "wire breaking monster" for a period of time.
notallhere,
i would NEVER buy a machine without the manuals, and schematics.
gotta keep em running or they are nothing but an anchor.
thanks guys!
Old 02-13-2007, 06:26 PM
rodneydeeeee is on a distinguished road
Try a few of these
We sell CAD/CAM and Wire EDM software. We are Dolphin CAD/CAM and can also be seen at www.cadcamconsultants.net.
Alot of customers use between one of the following...
Japax, brother, mitsibushi, sodick
All 4 are very good.
Old 02-13-2007, 07:47 PM
PoppaBear10's Avatar
PoppaBear10 is on a distinguished road
I ended up doing a Control retrofit on a Mits, cause the repair and cost of these machine is crazy, the mits guy wanted 6 k for ONE day of repair work. That is when I just retrofited it, (still a pain in the butt).
I retroed on Sodik, and it was much, much kinder and easier to work on.
I retrofited the machine with Mach, but, if you can find one with a working Fanuc, then it is usually worth salvaging/repairing.
OneCNC is an excellent source for Wire EDM, I use it my self and it is very easy to use with lots of usfull features.
On some of the older machines you have to watch the SCR's since they go bad after a while, filters and flow hardware is also an issue. Make sure the "Back off" circuit is working good, as well, or lots of broke wire.
Note: EDM is SLOW work, and speeds have only climbed relativly to what they used to be. Most shops around here charge about $8/hr machine time, or roughly 80/inch depending on machine speed.
S.
Old 02-14-2007, 06:19 AM
It certainly sounds like you have enough work to justify your own machine. At that rate, you could probably justify a new one, or a used one direct from the manufacturer that would come with full documentation and factory support.
You need several manuals with these machines, mechanical, programming, and technology. The technology books tell you the groups of electrical settings and offset values for various combinations of workpiece materials, cutting heights, and wire types and sizes. If you don't have this, you will waste lots of time trying to develop your own.
Most any machine that's running properly will hold the tolerances you want. Even plus or minus .0002" isn't too bad. Below that, some machines are much better than others.
Submerged cutting is the preffered method. Any time lost from draining and filling is more than offset by the faster cutting speeds. Some newer machines do not have to drain the tank to thread, and several manufacturers have concentrated on reducing non-cutting time with faster tank fills (drains are usually pretty quick) faster thread times and higher rapid schemes. I would suggest that for your type of work, none of that is particularly relevant. It is a small percentage of the total time to burn a part.
Cheers!
Roy Solomon
Old 02-14-2007, 10:07 AM
matsuura is on a distinguished road
Hi, you want to go submerged as Roy says, we have two Agie edm one is not submerge and it is day and night when cutting taper and the submerge one is cutting much faster,i would buy new ,take a look at Agie.
  #11   Ban this user!
Old 02-14-2007, 06:28 PM
thanks guy's, we're learning every day and don't even have one on the
floor yet! LOL!
looking at several machine's currently, who know's which one we will end
up with. after what pappabear said, probably not a mitsubishi.
looking at a hitachi, that thing is NICE!
any info on them? parts avalibility, tech support, etc?
  #12   Ban this user!
Old 02-15-2007, 11:00 AM
tomp-tag is on a distinguished road
2d work and +-.0005 ?
get an old agie 2d,
cheap, simple, very accurate and will stay accurate because the machine tool is good.
6000$ per month? you dont have really large amounts of work so a cheap accurate but slow machine is no problem
www.techstar.com has some, or you might fine one.
some of the earliest were submerged!, just small ( 6x6 )
great learner machine
regards
TomP
Wire Pulgs and Wire JerryFlyGuy General Electronics Discussion 7 03-04-2006 10:57 PM
Need help with wire!!!! jstern429 General Electronics Discussion 4 01-27-2006 01:42 PM
Very General ? 4-Wire/6-Wire cwoodall Stepper Motors and Drives 7 08-27-2005 05:52 PM
Wire EDM - RFQ itsme Employment Opportunity 4 08-04-2005 01:07 PM
Wire Saw creative_mind General Metalwork Discussion 1 04-20-2004 03:43 PM
