http://metalgeek.com/static/cope.pcgi This is something I have almost forgotten about, it is a simple program that aids in coping and notching tubing. You enter the tube size that is to be cut, the angle of cope, and the size of tube to be fitted to, and it then draws the cope out as a line that can be printed out, wrapped around the tubing, and then cut. The really great part, and the reason I put this in the cnc plasma section is that there is a built-in Gcode converter. I know, I know. It isn't a cnc plasma machine. But, for those that use one, it is a great time saver. Hope that some of you can use it.
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) "If the women don't find you handsome, they should at least find you handy" -RedGreen show. |
| I think I have seen a CNC tube coper. Turned the tube and moved the torch to make the copes. If you came up with a stepper tube turner, and could calculate steps/inch of circumference it wouldn't be that hard. At least untill you put the first bend in the tube. MIKE |
| Well, for radius arms, ladder bars, panhard bars, fence pipe, etc. it would be great. When the piece needs bending, well, that is a whole 'nother story. I would think it would be easy to setup. Get an old lathe chuck or something to clamp the tube in, spin it with a stepper with some gear reduction, and plug it in as your "Y" axis.
Pictures can be found here: http://torchmate.com/tm_accessories.htm
__________________ Mike @ Torchmate.com | www.Torchmate.com Toll Free : (866) 571-1066 M-F 7:30am-4pm PST |
Do you know of any other programs like this one that would calculate for larger diameter pipe, like 15" or 16" O.D.? |
| On something like that, I see people use larger torch bevelers that mount to the pipe. I forget the real, technical name for them.
| Not so much for turning them, but to be able to print the cope outline on the plotter to wrap the pipe with. We make some funky pipe tee's and diverter valves once in a while, usually on pipe anywhere from 12" up to a 36" piece we did recently. Tying to figure out the cope on some of those big ones can lead to alot of smoke exiting the ears! |
#10
#12
| Then go into the electrical department and ask for a 440 volt double phase breaker. Tell them it has to be slow blow. I love going there when I am having a bad day, I can always entertain myself.
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) "If the women don't find you handsome, they should at least find you handy" -RedGreen show. Last edited by massajamesb; 02-09-2007 at 04:09 PM. Reason: wrong info |
| bad laser tube | CNCadmin | Laser Engraving & Cutting Machines | 40 | 07-03-2007 10:23 PM |
| Sealed tube gas mix... | WilliamD | Laser Engraving & Cutting Machines | 6 | 12-10-2006 10:27 PM |
| Flame Tube | InfamousX241 | Jet Engines and Ram Jets | 2 | 11-05-2006 06:27 AM |
| Plasma tube notcher? | ty1295 | CNC Plasma and Waterjet Machines | 20 | 11-12-2005 10:25 PM |
| Coping a object around a axis? | CNCadmin | OneCNC | 4 | 10-15-2004 07:17 AM |
