Old 02-08-2007, 08:16 AM
Mini-MillX2 is on a distinguished road
Thermal dynamics extended tips cut vs Hypertherm fine cut
Does anyone have any experience with these tips? I'm trying to choose between getting a Powermax 1250 and a Cutmaster 101. I cut alot of thin gauge Aluminum and want the best cut I can get.
Old 02-08-2007, 11:49 AM
tinman13 is on a distinguished road
I am having issues with the Thermal start cartridges.....I'm wondering if I shouldn't have gone with the Hypertherm.
I'll have more info in a couple of weeks.
Steve
Old 06-30-2007, 09:20 PM
jballardtc is on a distinguished road
fine cut consumables
i'm runng a powermax 1650 cnc with fine cut consumables i cut 16 gage diamond aluminum plate @150ipm 40 amps on diamond side up no cleanup @ all. i was impressed
Old 07-01-2007, 11:41 AM
Torchhead is on a distinguished road
Since you cut at about 25 to 30A with Fine Cuts, any machine that take them (Hypertherm1000 and up) will give comparable results. A bigger plasma machine does not give better, tighter cuts in thin stock at a given amp setting.
The width of the kerf is a function of the tip oriface and the tip gap (distance of tip above the material). Fine cut consummables address both of those since the oriface is small and the recommended cut gap is less than the standard 40A and 60A tips.
Now, if you need to make good cuts in 1/2" plate with all the current you can muster to get straighter sides, then a 1650 will be justified.
Hypertherm and "Fine Cut" consumables alliance_metal CNC Plasma and Waterjet Machines 10 12-10-2008 02:48 PM
Thermal Dynamics Cutmaster 101 tuknrm CNC Plasma and Waterjet Machines 8 11-19-2006 03:52 PM
anybody compare HT finecut tips to TD 1Torch tips for dross? Knut CNC Plasma and Waterjet Machines 0 09-29-2006 01:17 PM
Start delay on Thermal Dynamics 151 Scratch CNC Plasma and Waterjet Machines 4 06-01-2006 11:22 AM
Drafts: Tips for vendors and tips for RFQ writers... InspirationTool Employment Opportunity 3 12-20-2005 08:44 PM
