| Has anyone done a CNC retrofit on a Heath, Torchmate, or other upright shape cutting machine? This style was popular 30-40 years ago for oxy-acetylene flame cutting. A motorized magnetic spindle followed a steel pattern. It would seem there are several approaches to a CNC conversion of a unit of this design. Ideas & discussion encouraged. As an aside, if anyone has an old motorized mag spindle, or plans for it, please PM me. Last edited by Weldtutor; 02-02-2007 at 07:30 PM. |
Sir, Several years ago I did a retrofit on an Airco Travograph machine which originally used a mag follower. At that time we made optical line tracers using rack and pinion drive for both axes. Thus it could have been CNC instead. (The Travograph was not an X-Y machine, but rather it was a combination of polar and Y motions, a little like what I think you are refering to!) We made an X-Y carriage which ran on their tracing table. This carriage was triangular shaped with the X axis about 1/2 the Y axis length. A drive motor on the X used rack and pinion to propel the carriage. On the carriage, there was a set of ways for the cross axis and a small motorized cross carriage was connected to the torch bar for the Airco machine. This added carriage effectively converted the machine to X-Y. We did many retrofits of rack and pinion drives to all sorts of cutting machines and all were rack and pinion drives. 94% of them were X-Y machines. Regards, Jack C. |
The Heath "Ultragraph" series of upright shape cutters had 2 linked arms to cover a circular work space, and were available either wall mounted or free standing. (Heath was taken over by Esab) I was thinking of a CNC conversion that maintained the arms, rather than building a gantry. |
second photo downloaded from ESAB's Website Actually seen one of these recently sell on EBAY, in the Washington state area, for somewhere just over $1000.00
__________________ If it works.....Don't fix it! Last edited by millman52; 02-03-2007 at 11:43 AM. Reason: addition to text |
I was thinking each of the two main joints could be CNC'd by a nut & ball screw or acme screw, with some limitations on area covered. A motor with timing pullies/belts at each joint would cover a greater area although possibly be somewhat more challenging to build. Is that about a 100 pound "hard drive" with the CAD (Customer Approved Designs) loaded there? = Beautiful story ![]() Your CNC machine is almost done! |
__________________ If it works.....Don't fix it! |
| Other CNC'd mechanical drives, properly designed and executed, would likely allow full coverage of the original work envelope. (Your CAD/CAM files in the picture sure would take a lot of "Filing") |
| also would probably have to somehow stabalize the pipe mast the arms are mounted to. There is quite a bit of bounce/spring in mine. The additional weight of motors, ball screws etc. I'm sure would make that even worse & most likely droop as the arms reach farther out to maximum reach. But after reading your post(s) I think it would be doable. I bought the one I have complete with 3 line torch & 3 regulators & hose for $350.00 I scrapped the "duck feet" leggs that it was attached to. Built the small burning table & mounted the machine directly to the table.
| Magnetic Chuck for Milling Machine...? | tdfsu | General Metal Working Machines | 8 | 03-19-2007 02:41 PM |
| Fanuc Magnetic Sensor Error | symage | General Metal Working Machines | 1 | 03-07-2007 04:02 PM |
| Info on Fet power follower for inexpensive small stepper driver? | mpmarino | Stepper Motors and Drives | 2 | 12-15-2006 02:57 PM |
| Concrete to stiffen mill upright? | Tristar500 | Benchtop Machines | 66 | 11-12-2006 09:21 PM |
| Cam- gear motor - force applied to follower? | Chris D | Mechanical Calculations/Engineering Design | 3 | 05-05-2006 11:41 AM |
