Old 01-28-2007, 03:34 PM
millman52's Avatar
millman52 is on a distinguished road
Question about belt reductions
I was wondering what width & pitch belts others are using & how much (3:1-4:1 etc.) on their initial reductions to operate a combination Ox fuel/plasma table. Will be using stepper motors.
If it works.....Don't fix it!
Old 01-28-2007, 05:14 PM
Torchhead is on a distinguished road
For Rack and pinion with a DP of about an inch (3.14 inches of travel per rev) a 3:1 belt reduction puts you back even where one rev is close to 1" of travel. From your steppers you can expect from 500 to 800 RPM (once again depends on the stepper voltage applied) with higher RPM at about 20 to 25 times the stepper nameplate voltage. That equates to 500 to 800 IPM. In reality you probably don't want more than 400 to 500 IPM so even more aggressive reduction will trade the speed you don't need for the torque you do.
A lot of tables have been build with 3/8" wide XL belts of .080 or .20 pitch. You of course need to match the pulley pitch to the belts.
Old 01-28-2007, 06:16 PM
massajamesb's Avatar
massajamesb is on a distinguished road
I know I have answered this one for you before, Neil, but I will answer on here for those who don't already know.
I have a 15 tooth pulley on my stepper, and a 40 tooth on the spur gear shaft, with .2 xl pitch pulleys and belts available here.
http://stores.ebay.com/HUBBARD-CNC-C...QQftidZ2QQtZkm
There are of course other places to get these, but I have always had good luck with Brent, who owns that store.
With my pulleys (15-motor, 40- drive) I have a 1:2.66 ratio, meaning that my motor must turn 2.66 (40/15) full revolutions to make one full revolution of the driven gear.
My driven gear is a spur gear, 20 pitch, 20 degree pressure angle, 20 tooth. For every revolution of the spur gear, my machine moves 3.14 inches (this will vary, depending on which spur gear you have being driven)
so, 3.14"/2.66 is 1.18" of travel for every revolution of the motor.
With this as just an example, figure out what the maximum speed you will need on your machine, and do the math backwards to help you find your desired gear reduction. There are a number of other factors involved in choosing your gear reduction and stepper motor, but this will help get you in the ballpark.
I hope this doesn't confuse all the newbies, and I hope I got it all straight without leaving anything out.
"If the women don't find you handsome, they should at least find you handy"
-RedGreen show.
Seeking Belt Sander Belt Source 6 x 48 Dugg General Metal Working Machines 3 12-24-2006 09:48 AM
Question for those with a x2 belt conversion ZipSnipe Benchtop Machines 2 05-13-2006 07:48 PM
SDP-SI timing belt pulley question cnc2k Mechanical Calculations/Engineering Design 4 08-21-2005 02:17 AM
timing belt question Aegeon DIY-CNC Router Table Machines 6 05-18-2005 09:50 AM
Timing belt/ratio question kinneycan CNCzone Club House 3 09-24-2004 04:20 AM
