Old 01-27-2007, 09:55 PM
JINX222 is on a distinguished road
Brother Wire Edm
What will happen if I try to power up wire EDM machine (Brother HS-3100) without connecting water tank to it ? I don't want to cut anything. Just want to see if I can move it in XY axes. Will machine let me do it, or there will be some kind of alarm blocking the whole machine ? Any precautions I should consider when starting this kind of machine for the first time ? I bought it used at auction so I don't know anything about it. The guy told me I should let technician take care of it. Is it necessary ?
Old 01-27-2007, 10:44 PM
mdynac's Avatar
mdynac is on a distinguished road
dude, just hook up the flush cart, it only takes a few minutes....
but i think the brother needs a di bottle hooked to it also, or just put
bottled water in the system, to ensure it is clean(don't use tap water)
if you don't put water in the system, the brother may alarm...(not sure)
however the machine should boot to an input screen even without water,
then maybe you can jog.....
the brother expert is craig at edmnetwork
go to edmnetwork.com
sorry i can't remember all the nuances of the brother as i don't work on very many...
good luck
Registered Linux User #348337
EMC2 Rocks!!!!
Old 01-28-2007, 03:46 AM
Karl_T's Avatar
Karl_T is on a distinguished road
I've got a different brand, but you shouldn't be able to hurt anything by trying to move it. Mine will even let you try to burn, the wire just promptly breaks and then you get shut down for wire broken.
Karl
brother cnc 100 wratey General Metal Working Machines 1 10-06-2011 05:05 AM
Spindle Repair-Brother TC-221 Ben Colby General Metal Working Machines 10 06-29-2008 09:02 PM
BROTHER HS-70A Post asylumua General CNC (Mill and Lathe) Control Software (NC) 0 04-12-2006 05:54 AM
Brother TC-215 CRT problems Rufan General Metal Working Machines 2 03-29-2006 02:23 AM
Drip Feeding To a Brother (TC-218) Igot2drip General Metal Working Machines 0 03-15-2004 10:50 AM
