Old 12-14-2006, 04:27 PM
alliance_metal is on a distinguished road
Hypertherm and "Fine Cut" consumables
I recently picked up a set of "Fine Cut" consumables for my PMX380. I haven't used them much and I was wondering if anyone else out here has or is using them regularly. If so, what are your thoughts? are they worth the extra couple bucks? I know they talked about extended life and whatnot, so I wanted to hear from anyone that likes or dislikes them for whatever reasons.
Andrew
Alliance Metal Art
Midland, Michigan
Old 12-15-2006, 06:54 PM
Apples's Avatar
Apples is on a distinguished road
Yeah they are the "bees knees". I use them to cut 3mm and 2mm steel with far better results than the 40 amp nozzles on my powermax 1000.
That is about up to 1/8".
Peter
Old 12-21-2006, 08:03 AM
joemic is on a distinguished road
I have experience to use the fine cut consumable to cut 1.5mm thick aluminium
for 4-5 days (8hrs/day). It pierce up to 3000 time before I change the nozzle and electrode. Fine cut's cutting less dross compare to normal nozzle for think plate
Joe
AC Meca
Old 12-21-2006, 10:44 AM
bossfrog's Avatar
bossfrog is on a distinguished road
Nice tips, but I am not getting the life that some others are - I cut 14ga, and the life varies considerably. Nice cut though...
Ric - Boss Frog
Old 12-03-2008, 03:11 PM
METALESESTRUCT is on a distinguished road
Has someone tried cutting in 3/16" mild steel with fine cut ... I have a 1650 Hypertherm and will like to cut some real fine parts. Any one has any ideas?
Old 12-03-2008, 11:22 PM
Pure-Powder is on a distinguished road
Talking
I cut 1/4 plate with Fine Cut consumables with my hypertherm 1000 , does a nice job!
Old 12-09-2008, 01:48 AM
slammedxonair is on a distinguished road
what kind of settings are you running to cut that? If you don't mind.
Old 12-09-2008, 09:15 AM
ipm 60 , arc current 52 , arc voltage 120
Old 12-10-2008, 11:48 AM
jimcolt is on a distinguished road
The FineCut consumables do not provide a life advantage over conventional Hypertherm parts....they are designed for finer cut quality on materials typically thinner than 3/16"....although I have heard reports of them being used on much heavier materials. It is important to use a torch height control system if doing mechanized cutting to hold the proper standoff (approx. .100") or to use the CE deflector shield for drag cutting....so the nozzle does not contact the plate.
Jim Colt
Old 12-10-2008, 02:42 PM
Cool Ill have to try it some time incase I have somebody that needs the most prcision I can supply short runs of course.
  #11   Ban this user!
Old 12-10-2008, 02:48 PM
Keep in mind those settings are with my Table, Plasma Unit , and THC... Your setting may differ... Use only as a guide at best, always do a sample cut on scrap first! Thanks Dennis
