Old 11-15-2006, 07:04 PM
joet1324 is on a distinguished road
stone cutting
Hi guys im new to the stone counter top cutting world and had a few ? for any one that would know i right now am running a cnc routor for a high end metal mill work company and want to do my own thing on the side so first ? is what is the best machine to cut stone water jet or a ring saw 2nd how do you get the bullnose and diff. egdes on the stone thats all for now thanks for all the help
Old 11-19-2006, 12:57 PM
DennisCNC's Avatar
DennisCNC is on a distinguished road
You can cut stone with a water jet if you have one sitting around, but it will add up quick as it cuts slow, all the straight cuts in stone are done with a diamond blade, the curvs can be done by hand with a concave blade, or with a finger bit on the stone router or water jet. Same thing for the sink cut outs. For the profiling you use a manual router that runs the bit shaped the profile that you want, here is the one I made: http://www.cnczone.com/forums/showthread.php?t=27570
Or a full size stone router that does all the profile work and sink cutouts at once.
Dennis
Old 01-21-2007, 07:43 AM
diamondblades's Avatar
diamondblades is on a distinguished road
Like dennis said you would use diamond blades for straight cuts, concave blades for curve cutting and possibly diamond tipped core bits if you need to do any drilling.
Diamond Resin Polishing Pads also if needed.
Good luck
MasterBlade.net
Diamond Tools
