Old 10-03-2006, 06:19 PM
howitt is on a distinguished road
Best 4 x 8 Plasma Table - Opinions Needed
Im ready to purchase a plasma table budget between 20-30k. Am I better off purchasing a used industrial machine like a MG or ESAB or a brand new such as a dynatorch. I Currently outsource 50K+ a year in laser cutting and feel I if bring it in house via plasma for a significant cost savings and better lead times. I only run 1 shift and most material we plan to cut is 1/4"-1/2". usage would be abotu 40 hours per week. Is it worth upgrading to high-def plasma unit such as an inner logic or hypertherm? I look forward to any opinions
Old 10-03-2006, 07:08 PM
PlasmaGuy's Avatar
PlasmaGuy is on a distinguished road
Laser versus plasma. Laser cleanup is nearly zero while plasma can involve considerable cleanup. Please take this into consideration.
Old 10-03-2006, 07:11 PM
It must of been my laser cutter because I had to clean up my parts all the time
Old 10-04-2006, 02:42 PM
Scratch is on a distinguished road
I don't know what kind of cutting you're gonna do, but In my opinion... Plasma is not the ideal method for cutting "parts"
I mean, artsy stuff like signs and things where tolerance is not an issue are great. But I do alot of cutting for vehicles where the tolerance has to be a consideration and I hate it. I'd much rather cut the artsy stuff that has more forgiveness that the parts I cut. I feel I can't compete with the laser and Hi-def guys.
I've been looking at the Hi-Def plasma cutting systems and the difference in cut quality is huge.... of course so is the difference in price... for me anyways.
Old 10-04-2006, 03:41 PM
Well the quotes I got for a 100-200 amp high def unit is about $25k and when you can a table for 10k, 35k for a high def setup inst bad
Old 10-04-2006, 04:23 PM
Yeah that's about the price I got too, but to me... it's a bit too high right now.
Old 10-05-2006, 05:25 AM
PlasmaGuy's Avatar
Scratch, you hit the nail on the head on high def v. reg plasma.
Even with a fine tuned plasma compared to high defintion the prep work required is rather large. Time = $$$
And as Howitt mentions the high def is > $$$
The accuracy of your table is very important too. I would not even consider high def on my 6 y/o Torchmate.
Old 10-06-2006, 11:45 AM
Ive consider building servo / ballscrew table my self running mach 3 with the innerlogic setup. I would have between 35-40k in that setup.
Old 10-06-2006, 01:19 PM
PlasmaGuy's Avatar
Innerlogic power source combined with the Dynatorch controls would make a nice match.
I have the Hypertherm 1650 and it'll cut like crazy but is definitely nothing when compared to high-def.
I believe fiber optic controls would be required due to the RF issues that come with the higher amperage machines.
I recall that Innerlogic and or Hypertherm are rather picky about the table on which there high-def equipment will be paired, i.e. the tolerances that the table can hold or not hold are directly related to cut quality.
Old 10-06-2006, 02:57 PM
Also I've heard that with the Hi-def torches, you need a table that has two drive motors for the bridge, one on each side, or you will see every gear movement in the cut.
  #11   Ban this user!
Old 10-06-2006, 10:07 PM
Kanman is on a distinguished road
howitt, take a look at Torch Mates web site. On their home page under Editorials > About Machine Accuracy > EXPLODING THE MACHINE ACCURACY MYTH. Was a pretty good little article to read. Here is a direct link http://www.torchmate.com/accuracy/index.htm
