Old 10-03-2006, 06:37 AM
turboboy is on a distinguished road
The correct tip for plasma?
Im running a hypertherm 1000 with ahnd torch on my cnc table with THC. Whats the correct tip to use on the hand torch?. They have sheilded or unsheilded they run? Thanks
Old 10-03-2006, 10:15 AM
luckeycnc is on a distinguished road
When you say "tip", do you mean electrode?
Jon
Old 10-13-2006, 11:13 AM
TMT89523 is on a distinguished road
Generally you want to match your tip with the amps you are cutting with ie 40 amps on plasma unit 40 amp tip etc. As far as shielded or unshieled I haven't seen a big difference in cut quality.
