Old 05-11-2006, 04:51 AM
Apples's Avatar
Apples is on a distinguished road
Thinking of selling my CNC plasma table, what price to ask?
I am thinking of selling my whole plasma table setup. I would just like to find out if someone would be able to give me a ball park figure of what I might be able to sell the whole set up for.
3meters x 2 meters.
Running off Gecko’s
2x 1200oz steppers on X axis
1x 270oz stepper on Y axis
1x 270oz stepper on Z axis
48Volt power supply at 13amps
THC
Comes with the computer with Mach 3 and SheetCam already installed
Comes with a virtually unused Hypertherm Powermax 1000 plasma cutter with machine torch.
The photo’s can be seen at the yahoo ‘plasma cutting’ groups website under photo’s. It is the photo folder called ‘A plasma table in Australia’.
Yeah so I am just trying to work out how might I might be able to sell it all for.
Peter
Old 05-11-2006, 03:09 PM
energyforce is on a distinguished road
It would probably help to have actual pictures or a www link on here cuz some people (like me) are lazy and dont want to search all over yahoo (ive never been to this yahoo place). Id like to see more pics of your table though.
Old 05-11-2006, 06:50 PM
midiguy732 is on a distinguished road
Since you're a nice guy Peter, let me help you out.
Ship the system to New Jersey, USA, care of me, and I'll evaluate the system for one year, then write up a report as to it's value - at no charge to you.
Old 05-11-2006, 07:02 PM
Salty72 is on a distinguished road
APPLES
how much work has it done?
is it a homebrew cutter ?
what is it's TOL / Accuarcy
how thick does it cut (guess i could work this one out if I looked up the cutting tourch)
where in gods own country are you ? as my olds are in Mt warren Park and I'm looking for a machine..
PM me or flick us an E-mail XXXXsalty72@XXXXtsn.XXXXcc (please note the additional charactors)
Also some photos here would be a must
Old 05-12-2006, 12:55 AM
Apples's Avatar
Okay it is a home brew job.
I live in Qld Toowoomba.
The tolerance/ accuracy is okay in my opinion for a homebuilt rig.
It will never have the accuracy of a laser or an oxygen hi-definition setup. The air plasma's simply just do not have that ability to be that accurate. Anyway they cost big big dollars!
My machine I have found can get actually pretty good tol/accuracy's for a home built machine.
Like if I cut out a thing say 1 foot by 1foot and it will come out within say 1-2mm of it. Probably better that that actually, I don't want to say it can hold 0.5mm if it can't do it.
The plasma cutter is hypertherm powermax 1000 with a machine torch. These plasma cutters are the 'mercedies bens' or 'rolls royce' of plasma cutters. The thickness that I have cut is 10mm, the machine is capable of cutting 25mm steel.
How much work has it done? Well I have cut probably 1 full sheet of 5mm steel that is 3meters long by 1.5 meters wide. And then a couple small bits of 10mm scraps and a few small scraps of 1.5mm.
The accuracy and cutting capabilities of this machine are more than what I expected that I would get from it. I have cut out the uprights for bullbars and made a big bullbar for a landcrusier. I have made a homebuilt ring roller with the plasma. I have made some diff guards with the table. And really this is so good because you can just about make anything with it.
Going back to the accuracy, for what I have made it is plenty accurate. Anyway if you are just making parts that have to be welded anything that has to be highly accurate is going to warp like crap anyway.
I will drop in some picture here to show you some things that I have made and the machine etc.
ID:	18006   Click image for larger version
ID:	18007   Click image for larger version
ID:	18008   Click image for larger version
ID:	18010   Click image for larger version
Old 05-12-2006, 12:59 AM
Apples's Avatar
This part was cut and welded as mounting brackets for a bullbar.
ID:	18012   Click image for larger version
ID:	18013   Click image for larger version
ID:	18014   Click image for larger version
Old 05-12-2006, 01:02 AM
Apples's Avatar
Made a ring roller. cut the arms out of 5mm cut the base out of 10mm. Used it to roll the ring bit of this diff guard that was also cut on the plasma
ID:	18016   Click image for larger version
Old 05-12-2006, 01:04 AM
Apples's Avatar
just some other pics
ID:	18018   Click image for larger version
ID:	18019   Click image for larger version
ID:	18020   Click image for larger version
ID:	18022   Click image for larger version
Old 05-12-2006, 07:58 PM
carbidecraters's Avatar
carbidecraters is on a distinguished road
Might be worth 4K...hard to say with all the budget cnc plasma's out there its hard to sell a home built model
Old 05-12-2006, 08:06 PM
Apples's Avatar
4k would be about 6k in Australia I think.
The plasma cutter here in Australia with the machine torch is $6450 alone.
Peter
  #11   Ban this user!
Old 05-13-2006, 06:50 PM
NC Cams is on a distinguished road
I"d look for a comparably sized/capable commercial one and price it at roughly 30% to 50%. If you can get your cost out of it, consider yourself lucky.... The parts you made and the learning experience is where you really made out well on the project....
You'll be lucky to get it (your build costs) simply because a commercial one will be percieved to have higher "value". Also, serviceabilty is going to be there, or at least should be, simply because it is a commercially serviced item.
I bought some "home brewed" hardware and when it worked things were cool. When it screwed up, which it did, I learned that it wasn't worth the savings in lost time and flow down damage it created when it stopped working (and damage other stuff in the mean time)...
Although DIY projects can be as good if not better than commercial made (yours is a nice piece), a businessman will usually buy a "name brand" simply because if/when it goes down, he can call a service guy to come and fix the thing....
Getting someone who built a DIY piece to come back and fix it can get real old, real quick and especially so if they eventually (and they do) quit answering the phone....
HINT: A nicer the package (as in painted frames, fully boxed/enclosed controls, etc) would make it much more presentable. No offense but although it surely appears to have worked well, it looks too hobby-like "open-ish", not professionally built and not shop robust enough to interest a person looking for use in a "buy it and run it" in fab shop use environment.
Unless you can find a person with a similar interest in the technology as you, the above hurdles are typically faced by DIY'ers who eventually try to sell their creations.
  #12   Ban this user!
Old 05-14-2006, 02:47 AM
DSL PWR is on a distinguished road
Your best bet would be to part out the machine.
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
