| Smart a$$ reply: All over this message board. Serious reply: SPECIFICALLY, what KIND OF CNC machine are you interested in building???? Your inquiry is impossible to answer in the way it is currently pose. Do you want to make a Mill, Router, Lathe, Engraver, plasma cutter, robot, welder, pick-n-place robot, CNC what????? Big difference. You need to be more specific as to what you want to do, how much you want to spend, what do you know about mechanicals, electricals, limitations, size, your skill level etc, etc, etc. There is a lot of expertise and knowledge to be obtained here however you do need to be much more specific in how you go about asking for it... It also helps to do a bit of studying into your area of interest so that you understand the communication flow and/or the tech terms once you do enter into discussion about your area of interest. In the mean time, look, read, study, enjoy... Once you figure out what you want to do, check back for help with prime focus in your/the particular area of interest. Again, be more specific in your inquiry when you do. |
First of all lets say that I'm new to cnc zone and was introduce to the zone by my instructor. The type of machine I'm interested in is a plasma cnc. And you're right I do need to read and study up in this field,THAT was my question were can I get started on getting this information so that I can learn not only the basics but how everything works. I'm very mechanicaly inclined a 15 year electrician, a welder, I've taken and completed cnc lathe and mill and currently taking up mastercam, price no object, I would like to build a nice cnc plasma cutter, which I already own the plasma machine. The only thing I need to know Is WHERE and HOW do I find the information to get started (literature,input,direction)so I could obtain and get the knowleged of building such machine. How to get started thats all I asked. |
| Try this: Go to search engine on this site. Type in "plasma cutter". See where it takes you. Then try the following: Try "cnc plasma cutter". try "DIY cnc plasma cutter". Try "cnc retrofit plasma cutter". Do the same on google and/or teoma. Sometimes, the hardest thing to do is to learn how to look for something..... The above ideas should yield even more on how to find where you want/need to go. Half the fun of DIY anything is figuring out how to do it and learning how to do research is part of the challenge. |
| There are several great threads on here by fellow builders, spend alot of time at each one, ask questions and then determine how you will build yours. I can tell you the people on here are the best in the industry as far as willingness to share ideas and help you out. My personal favorite forums are by mlaws1172, weldtutor and mine. Think about what you really want to do with your table, then work on the table design, control package, and your software package. To give you a hint I am a Facilities Manager in a manufacturing plant with two kids, I thought I could build a table in a couple of months, but I am going on almost 6 months ( this is a hobby, ok its more of a passion). One other thing to think of, not all plasma cutters are compatable with a plasma table, some units will literally fry your CNC controls. So reseach everything and dont assume anything. Ok now that the disclaimer is out of the way, ask away I have found that people are glad to share there knowledge and experience including me. Andrew Last edited by smilewizard; 04-17-2006 at 09:13 AM. Reason: Spelling |
Click on these underlined areas below. http://www.artofcnc.ca/ This is a site for a popular software. http://www.geckodrive.com/ These are common drives used. http://www.cnczone.com/forums/showthread.php?t=16634 See post #86 of this thread for a list of electronic components, as well as other information. The above should get you started, but are just a few of the many sources available. You will have to decide on type & size of motors to use. Servo or steppers & the voltage depending on the motor selected & speed needed for the range of material thicknesses you will be cutting. Mechanical drives that others have used include ball screws, rack & pinion, timing belts & pulleys, roller chains etc. These vary greatly in cost as well as positioning accuracy. |
| Part of the learning process should involve how to ask a question. You asked, "...Where can I get Detailed information on not how to build a cnc machine..." yet you didn't even mention what kind of machine you were talking about until the 2nd or 3rd post. Yet, EACH of the references cited in my a prior post could have been found using the google/teoma search methods suggested. Your generic unspecific and undetailed question got a response in-kind - no more, no less. Besides, I was trying to stimulate replies from other members with specific experise in the varous areas you'll need to have help with. By the way, I found this website and became a contributing "smart a$$" member thereof by using the EXACT SAME search google/teoma search method I proposed earlier. Ask better questions and perhaps, maybe, you'll get better and more custom specific and detailed answers. In the mean time, you may find the following to be of help (by the way, most of which were found using the searh function found/contained on THIS website): Daisychaining ATX power supplies: http://www.cnczone.com/forums/showth...015#post142015 http://forums.bit-tech.net/showthread.php?t=108208 Linear P/S design/construction http://www.campbelldesigns.com/files...ply-part-1.pdf Bearing literature: http://www.bardenbearings.com/literatr.htm http://www.timken.com/products/bearings/catalogs/ http://www.jp.nsk.com/app01/en/catal...gi?ec=bearings Get the NSK E1102 catalog for starters Motor torque info/defininition http://www.merkle-korff.com/formulas.asp#con What gage wire to use: http://www.cnczone.com/forums/showthread.php?t=17350 http://www.cnczone.com/forums/showth...480#post136480 Servo vs Stepper: http://www.cnczone.com/forums/showthread.php?t=17419 Simply stepper info: http://www.parkermotion.com/catalog/catalogA/A12.pdf Stepper reverse engineering: http://www.doc.ic.ac.uk/~ih/doc/stepper/others/ Stepper sizing: http://www.cnczone.com/forums/showthread.php?t=17707 Small stepper P/S http://www.campbelldesigns.com/files...ply-part-1.pdf |
| Although it may not seem like it, I believe that NC Cams is sincerely trying to be helpful. And asking more specific questions will usually get you a lot more replies than a very general question.
#10
| I was also trying to explain without being TOO snotty nor TOO condescending that one needs to formulate a question properly. By doing soe, one will more often than not get a focused, non-rambling, specific answer. Apparenlly I fell short of the remark or too close to the target - dunno which. Frankly, next time I'll use terminology that is more readily understood like: You question can't be answered becasuse it is simply too vague and ill constructed. BUT that would be surely be perceived as being too smart a$$ed as well. Hmmmm. What is a person to do??? If I am a smart a$$ who KNOWS the answer, and can usually provide it in inordinate and boring detail, what do you call an individual who doesn't know how to ask a question who also DOESN'T know the answer??? Seemed to me that the person who made the inquiry needed help in more ways than the simple (?) answers he was looking for. Hence, I figured a brief lesson in how to do research on the internet might be of help. Clearly, a lesson that was NOT recognized nor appreciated for its intent. If you don't want to learn how to do things (including how to research a topic), visiting a DIY message board is perhaps the wrong place and way to try to learn how to design, enginer and buid a plasmac cutter (or a cnc anything). In this case, the person might be better off buying a prebuilt/pre-engineered kit from somebody and bolting it together. Chances are he'll be be much happier because DIY CNC involves thought and figuing and some study/reasearch on the builders part. Some answers have to be figured out and not merely posed and answered by somebody on a message board who has already taken the time to learn how to do it.... Sorry, Mr. Moderator. that's as nice as I can be under the circumsances. |
#11
#12
First, you need a PC running machine control software. The most popular hobby option is probably Mach3, from www.artofcnc.ca To make the machine move, most people either use stepper motors or servo motors. These are powered by stepper drives, or servo drives. Mach3 sends step and direction signals to the drives, which then "make the motors turn". You'll need a power supply, usually between 24V and 80V to power the steppers or servos. The motors are then connected to leadscrews, or sometimes a pinion gear running on a gear rack. The leadscrews or rack and pinion create motion. The moving parts of the machine run on linear bearings. There are several different types. Precision ground round shafts with Thomson ball bearing bushings. THK type rails and bearing blocks. Search Ebay for linear shafts, and linear rails, linear guides... for plenty of examples. There are also homemade linear bearings, consisting of simple ball bearings riding on steel shafts. Another type is the BishopWisecarver DualV system, which you can see at www.bwc.com Basically, add your torch to the machine, and let the the control software run your machine. I'm sure you have more questions, so fire away.
