02-24-2006, 10:43 AM
Hello everyone,
At this point I have a 5' X 10' plasma table. I got a kit from camcutcnc.com. It is using a x and y axis stepper motor. and the program it is using to convert is there own, which then you have to use cncpro (dos base). I am in bad need to use a better program for everything and also need to get a thc for it. I downloaded the trial of mach 2, for some reason it is not responding to the gcode machine. Also I am using autocad for the design which I need to convert to a polyline before the gcode program will create a path for it. bottom line is, is it better to get another gcode converter that is already for the mach 2 program and a cambell thc. and if all is good where would you suggest buying it all.
Thanks Mark |
