Old 01-05-2006, 01:01 PM
AZCoyote is on a distinguished road
Two questions
First question: On a small plasma table (30 x 40) with a light Aluminum gantry, is there any good reason to drive the X axis with two steppers or is one enough? Assuming the gantry is tight and square. (All my steppers are 200oz)
Second question: If a 3 axis controller drives x,y, and z, what additional axis does a 4 axis driver control?
Old 01-06-2006, 10:46 AM
jcc3inc is on a distinguished road
Plasma cutter
Sir,
If you use a substantial main rail, and have good bearings in contact with said rail having a reasonable distance between front and back sets, this "delta braced" setup will NOT need two sets of drives. We made machines up to 6 feet wide having this configuration for plasma cutting, and they worked well.
I will enclose a pix of one approach.
A plasma cutter is a two axis machine; the third Z axis responds to initial height setting, arc voltage sensing during cutting, and retract at the end of the cut. A suitable auto-torch-height-control will do this job.
Regards,
Jack C.
