Old 12-13-2005, 07:35 PM
Weldtutor's Avatar
Weldtutor is on a distinguished road
Shop Air Cleaner For Plasma Cutting
To provide cleaner shop air, when using a CNC plasma cutting table, which system do you prefer?
Some Considerations: -downdraft through the table with outdoor exhaust
-overhead canopy with exhaust
-local pickup at torch to exhaust
-electronic air cleaner
Your thoughts & comments on this important issue would be appreciated
Old 12-13-2005, 09:04 PM
Brian Kidd is on a distinguished road
Good question, I've been thinking about this lately too. I want to eventually build a table for my brothers ESAB Plasma and was trying to figure out some sort of system that didn't cost an arm and a leg yet worked.
B.Kidd
Old 12-14-2005, 12:23 AM
DSL PWR is on a distinguished road
B.Kidd
Water table...
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 12-14-2005, 03:37 PM
Weldtutor's Avatar
DSL_PWR
A water table is one method I hadn't mentioned.
Can anyone suggest some design considerations for such a system & its' use?
Perhaps water depth, proximity to cutting surface, effectiveness of air cleaning or other items.
WT
Old 12-14-2005, 03:50 PM
I knew about the water table but for me it really isn't a good option. The machine will only be used periodically in the first place (unless I start getting some business) so with having to deal with water sitting in the table for long periods of time just doesn't cut it (no pun intended ). I have thought about some sort of closed off table that had some sort of evacuation system from a pipe that would be hooked up to the inlet on a squirrel caged blower and dumped outside.
B.Kidd
