Do I need a CPC port on the Powermax when connecting up the LCTHC? Or, can I just go no CPC and connect it the same as the powermax 45 internally?...when using a machine torch. Last edited by foam27; 01-29-2012 at 10:21 PM. |
| All of the Powermax45's come equipped with a CPC port. On the Powermax65 it is optional at the time of purchase, but can be added at any time (order part number 228696 from a Hypertherm dealer). The CPC port on a Powermax65 (or 85) has the plasma start input (active only with machine torch plugged into power supply), has the arc transferred output (also know as "arc good", "ok to move", "machine motion"....depending on the device you are interfacing) and it has a voltage divider output (factory set at 1/50th of arc voltage, can be reset to 1/21.1, 1/20, 1/25 or 1/40 of arc voltage by setting a dip switch inside unit) Internal connections for a cnc machine interface would require reading the schematic and cutting and splicing wires....I would not recommend doing it this way for safety and warranty issues. Jim Colt Hypertherm |
| I have a 65 working with the LCTHC. If you have the CPC port, you only need to provide the raw arc voltage. The LCTHC won't take the divided voltage. The raw arc voltage is accessible from the PCB on the lower left front of the machine. I drilled a small hole in the rear panel and ran the leads from there to the THC sensor card. All of the other leads are available on the CPC port. I have my sensor card mounted in a plastic project box and velcroed to the side of the 65. Willy |
| I can provide detailed instructions in a .pdf file (from Hypertherm) for making the Raw arc voltage connections. You can email me direct and I will send it back to you jim.colt@hypertherm.com Jim Colt Hypertherm |
| I did not recieve the RJ45 to DB9 adapter with my LCTHC.... I can go buy one at the electronics store, does anyone know if it it a straight through, null, or other config? when you buy these adapters you have to set the pins from RJ45 to DB9... |
| Need Help!- CANDC.com LCTHC | diyengineer | CNC Plasma and Waterjet Machines | 3 | 02-18-2012 12:37 AM |
| CNC powermax 45 VS 65 VS 85 | diyengineer | Hypertherm Plasma | 21 | 08-15-2011 03:18 AM |
| Good Experiences with LCTHC System | sbalder | CNC Plasma and Waterjet Machines | 2 | 06-16-2011 11:49 AM |
| CandCNC LCTHC | Carter3 | CNC Plasma and Waterjet Machines | 4 | 03-02-2011 07:50 AM |
| Powermax 45 help | binfordw | Hypertherm Plasma | 10 | 12-07-2010 11:37 AM |
