Old 01-25-2012, 11:17 AM
adscnc is on a distinguished road
DIY magnetic torch holder
i'm interested to know if anyone has been tempted to make their own magnetic torch holder. From the designs i've seen its needs magnets to hold it and a small tapered recess to locate it.
I guess there needs to be some trial and error on both the magnetic hold and the tapered recess. try it and see if it works ...
Old 01-25-2012, 11:33 AM
keebler303 is on a distinguished road
I think I have seen home made ones here. Did you search?
Matt
Old 01-25-2012, 11:53 AM
WSS's Avatar
WSS WSS is offline
WSS is on a distinguished road
I built two using 30mm square magswitches and some aluminum, they worked OK. I just did a major rerto-fit to our table and decided to use a snap 'n cut to save time. I wish I had done that a long time ago. It is simple and effective, it realigns perfectly. Comes from Oz but I had it fast. Cheap too for what you get.
WSS
www.metaltechus.com
Help with torch holder issue...crashing is bad... jgramlich CNC Plasma and Waterjet Machines 3 10-25-2011 07:08 AM
hand torch holder advert CNC Plasma and Waterjet Machines 0 10-16-2011 05:16 PM
Magnetic machine torch breakaway mount for DHC2 Benderart PlasmaCam 0 12-14-2010 04:33 PM
CNC machine torch holder AbachBua CNC Plasma and Waterjet Machines 3 01-02-2008 08:21 AM
machine torch holder Erick Davidson CNC Plasma and Waterjet Machines 5 06-11-2006 12:32 AM
