Old 01-13-2012, 11:25 PM
hrfab is on a distinguished road
Talking xPyro - IHS+THC Powermax 65 50" x 122"
Saludos,
Aqui les dejo fotografias de mi ultima maquina cnc plasma.
Hi, this pictures are about my last cnc plasma machine.
-50"x122"
-Geckodrive g540
-Nais Power Supply
-Lee Pillow Blocks
-Martin Spour Gears and timming pulleys
-Jason and Gates timming belts
-Kelling Technology Nema 34 Stepper Motors
-Bishop Wisecarver V Groove Bearings and rails
-Tol-O matic Z slide with initial height sensing
-Parker limit switch
-Proma Elektronika Torch Height Controller
-Powermax 65 modified torch
-Sheetcam & Mach3
pyrocnc.com
Tijuana, BCN Mexico
ID:	150126   Click image for larger version
ID:	150129   Click image for larger version
ID:	150130   Click image for larger version
ID:	150135   Click image for larger version
ID:	150136   Click image for larger version
ID:	150137   Click image for larger version
ID:	150139   Click image for larger version
ID:	150140   Click image for larger version
ID:	150141   Click image for larger version
Old 01-16-2012, 07:44 AM
fanefane is on a distinguished road
Hi. This is an awesome project, it is well built and constructed! Congratulations!
Are you satisfied with the Proma Elektronika Torch Height Controller? I've started a project too (with a PowerMax 65), and I have almost finished it, but I think to buy the same Torch Height Controller.
Old 01-16-2012, 12:18 PM
Proma Elektronika
Hi Fanefane,
Thanks for your comment. Proma Elektronika THC is simple to wiring, universal and very affordable by today. I think it must to have more inputs to adjust the parameters while the machine is running. Is like a PID controller size and you cant believe that small thing will works but it does works fine.
Alberto, Mexico
Old 01-19-2012, 08:09 AM
jimcolt is on a distinguished road
Just a suggestion....the Hypertherm Powermax 65 plasma.....like all plasma systems has a directional cut quality. In the video....all of the cuts are being done in the wrong cut direction! Holes should be cut counter clockwise, the outside contour should be cut in the clockwise direction.
Think of the plasma torch cutting into a plate and moving away from you....the right side of the cut kerf will have better cut quality in terms of angularity and dross, the left side will have more dross and angle.
Jim Colt Hypertherm
Originally Posted by hrfab View Post
Saludos,
PYRO X - VICISA -CHIHUAHUA CNC PLASMA - YouTube
-50"x122"
-Geckodrive g540
-Nais Power Supply
-Lee Pillow Blocks
-Sheetcam & Mach3
pyrocnc.com
Tijuana, BCN Mexico
Old 01-19-2012, 04:16 PM
Thumbs up Jim
Thanks Jim for the advise, powermax 65 cut amazing even in wrong direction!!!. I purchased Sheetcam last week and im studying all his features for plasma cutting. Thanks again for the help.
Alberto
Old 02-04-2012, 04:02 PM
salt is on a distinguished road
Proma THC
I am new to the CNC world so please excuse some of my silly questions...
I have built a CNC plasma table, the X, Y axis are cable driven and the z axis (lead screw) has a footing head... I have also purchased a Proma THC and I need some pointers as to the correct way in wiring it. For example, is it stand alone and wired directly to the stepper motor on z axis OR is it wired to the stepper motor drive? Also, can I still use the floating head assemble with this THC?
Any advice you could provide, would be much appreciated...
Cheers Tyrone
Old 02-04-2012, 04:44 PM
From what I can see online....the Proma THC is simply an arc voltage feedback circuit. This is used to monitor the arc voltage of a plasma torch and compare it to a knwn voltage.....then it closes a contact if the voltage is too high....or closes another contact if the voltage is too low.
An interface will have to be designed to accommodate:
-initial height sensing
-pierce height retract
-pierce height delay
-Plasma start
-corner avc lockout
-kerf crossing
-end of cut retract
-interface connection with x axis drive motor
I suggest communicating with the manufacturer to see if they have suggestions for making bthis unit work as a functional torch height control.
Jim Colt Hypertherm
Originally Posted by salt View Post
Cheers Tyrone
Old 04-07-2012, 12:39 AM
Screen para Mach3 en español
Old 04-07-2012, 12:52 AM
gzm.pepe's Avatar
gzm.pepe is on a distinguished road
este es el mío, aún le estoy puliendo unos detalles pero casi está listo
Tags
cnc, g540, hypertherm, plasma, sheetcam
how long "should" powermax 45 consumables last? mkweiss222 Hypertherm Plasma 6 01-16-2012 12:47 PM
40" x 20" Tree Vertical CNC Machining Center "VIDEO" VMC 1050/24 24 ATC Dynapath CNCadmin EBAY ADS 0 12-20-2011 06:20 PM
"NEW" 1/8" 5 FLUTE CARBIDE END MILL "AlTiN" CNCadmin EBAY ADS 0 11-06-2011 01:00 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
Need Help!- Powermax 1000 intermittent "no start" problem MoparJon CNC Plasma and Waterjet Machines 14 12-17-2008 02:59 PM
