Old 11-10-2011, 12:00 PM
mabencomo is on a distinguished road
Exclamation New Plasma Build
Need Help! New build cnc plasma build. Want to connect 2 two stepper motors to X axis. How do you connect them so they are going same direction?
Old 11-10-2011, 11:59 PM
4R8 4R8 is offline
4R8 is on a distinguished road
Without being rude
Step 1 - Search
Step 2 - post question with a decent amount of info.
Failing that I assume you're using mach 3?, if that's the case
see Winegar's thread from here
http://www.cnczone.com/forums/plasma...tml#post963431
This is the mach settings for Slaving you 'A' axis to you X/Y providing the wiring is identical between A and X/Y.
Just remember to do any testing without the two motor mechanically connected to drive the axis.
Hope that gets you heading in the right direction.
5' X 4' Plasma Build austin.mn Plasma, EDM and other similar machine Project Log 47 01-24-2012 08:44 PM
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
Plasma - Should I Build? Geordiepom CNC Plasma and Waterjet Machines 8 02-11-2008 08:30 AM
Plasma build jhuddleston CNC Plasma and Waterjet Machines 18 02-05-2008 09:34 PM
