Old 10-29-2011, 02:03 PM
NorthridgeFab is on a distinguished road
Z Axis info
Ive been doing some research on building my Z axis floating head and have some questions.
1. What revolution should I look for in the lead-screw and nut? I've seen guys running everything from .25 to 1.
2. The suppliers Ive looked at for the lead-screw do not list the back-lash. For ex, mcmaster's precision acme lead screws. Should I just measure the BL once the Z is built then have mach compensate for it?
3. I planned to use mcmaster's Precision Subminiature switch. Will mach let me compensate for the travel length of the switch?
Old 11-04-2011, 12:31 AM
WSS's Avatar
WSS WSS is offline
WSS is on a distinguished road
I bought this one to use with CandCnc and Mach. Can't build one for the price.
K2 6" travel. Has the float switch mounted and ready to go.
http://www.k2cnc.com/shop/proddetail.asp?prod=ZA600P-S
www.metaltechus.com
Old 11-04-2011, 07:08 AM
I Lean is on a distinguished road
Ecommerce Templates - Virtual Silver
I did the same thing, only in the 4" version.
Carl
New Machine Build- 4th Axis info?? Wallybanger General Metal Working Machines 2 07-23-2011 05:04 PM
Need info on 4th axis for NM-135 tas99 Novakon Systems 8 02-18-2011 08:19 PM
4th axis info wanted. two4tom Tormach PCNC 1 09-14-2010 11:56 AM
C Axis info Koalas Fanuc 0 03-12-2009 01:41 AM
need info on 4 axis machining greggv General Metal Working Machines 7 02-18-2005 12:08 AM
