Old 08-13-2011, 07:03 PM
jeffrey001 is on a distinguished road
Is this little plasma cutter good for CNC
I would like to build myself a small CNC plasma cutter and would like to use my little plasma cutter I bought last year.
Ramsond SunRay Pure Sine Wave Inverters
Can it be use for that, Cutting area will be around 2 X 4 feet.
Maximum material thickness will be sometime 1/4 but mostly 1/16 or 1/8 .
I don't want to use it often because of smoke and bad air quality it introduce in the shop.
I've already built a CNC router and it work great so building a smaller machine should be easy since I have a CNC mill and a welder.
What are your recommendations for a good THC that is somekind of plug and play.
Thanks, Jeff
Old 08-13-2011, 07:44 PM
flyinwilly is on a distinguished road
Jeff:
I used a Gianttech Cut40D as my first cutter when I built my table. See my build, New Machine Build- A Different Machine - Downdraft/water table , and it will answer most of your questions, including the THC. These chinese, contact start cutters present a lot of problems but they are all solvable. I got very good cuts while I was using it. The only reason I changed was to cut much thicker material. I actually think the cut was better on the thin material , under 18 ga, than the hypertherm although the PMAX 65 is much better and faster on thicker than 14 ga.
Good luck,
Willy
Old 08-14-2011, 03:56 AM
Thanks for the reply, will read all your post and see what I can do,
Again, Thanks
Jeff
CNC Plasma Cutter, Laser Cutter, Water Jet antsals CNC Plasma and Waterjet Machines 6 03-11-2011 06:56 AM
Tile cutter rail/slides any good? quadtech DIY-CNC Router Table Machines 8 04-14-2010 06:24 AM
CNC Laser cutter versus CNC Plasma cutter? squale Laser Engraving & Cutting Machines 10 04-26-2009 04:59 PM
a good plasma cutter for home nc9933 General Metalwork Discussion 3 11-02-2008 09:55 AM
Good Foam Cutter CAM Software? vacpress General CAM Discussion 0 03-30-2004 05:26 PM
