Old 04-15-2011, 01:11 PM
Millpremac is on a distinguished road
Can anodized Aluminum be plasma cut
Looking to do some CnC plasma cuts on some anodized Aluminum, but before I get into it, how well does it cut. Will it cut ok or will it destory the anodization? If it does cut ok, the immediate area around the cut, does that come out looking ok? Any help in this will be greatly appreciated, thanks for your time.
Old 04-15-2011, 03:46 PM
Med-Pac is on a distinguished road
I would not recommend cutting anodized parts. It can be done, but it is going to look like hell. Your edge quality will be slightly better than horrible, and you're going to burn away at least 1/8 of the color away from your cut path.
I would suggest cutting the parts first.......then anodize them.
Just my 2 cents, hope that helps ya.
Mike
Old 04-15-2011, 03:47 PM
1/8"....whoops forgot the "
Old 04-17-2011, 08:38 PM
Thanks Mike, that is exactly what I figured. I just wanted to hear from somebody that actually knew.
Black Anodized Aluminum Sample fullspeceng Laser Engraving & Cutting Machines 24 08-12-2011 10:27 AM
Engraving Anodized Aluminum: chipping? Frogblender Engraving Machines 7 03-17-2010 12:46 PM
Nickel plating on anodized aluminum stag53 Mass finishing equipment/media/stratigies 2 04-08-2008 05:00 PM
Engraving in anodized aluminum fish09 Engraving Machines 6 08-24-2007 04:02 PM
Anodized Aluminum Round Rod - Best Place To Buy It? nlh General Material Machining Solutions 0 12-02-2005 09:54 AM
