02-04-2011, 09:13 AM
Originally Posted by jmschamness LOOKING FOR SOMEONE TO HELP ME TO HOOK UP CUTMASTER 52 AND MP3000 THC. ON AND OFF, OK TO MOVE AND TIP VOLTS. THANKS JAY |
The 52 is relatively easy to automate using a cable available from Thermaldyne part#9-9385(verify pt# with Thermaldyne) and cost around $40.00. It is a 2 foot long harness with a 8 pin plug that plugs into the pcb board. It gives torch on/off and "OK to move" signal. Look at the wiring diagram for torch to get correct pin numbers. The voltage for THC is from pins on the pcb board. Hook the wires up to the correct pins for the MP3000 and you should be set. Here is the TD automation people I talked to 888-832-3477. They called it a "Basic CNC interface wire hareness".
Good luck
Mike |
