Old 01-28-2011, 06:15 AM
gmh265 is on a distinguished road
Plasma Cutter unit choice?
Hey Everybody,
I am slowly working on my CNC plasma table and would like to purchase the actual plasma unit shortly so that I can use it for a job that I have coming up (use it manually that is)
I would like my cnc machine to cut between 19mm - 25mm of steel/alloy if possible. I have 3 phase power available.
Why do some of the thermal dynamics machines quote a cut thickness for manual cutting then for a CNC cut with the same machine the cut thickness is only about 1/2? do they quote an edge start for the cut thickness manual mode or is it something else?
I was looking at a TD A60 machine that is in my price range, there is also a TD cutmaster 25 that looks like it can handle 25 mm cuts but could it do this in a cnc setup?
anyone used either of these machines in a cnc setup? any other machine suggestions?
cheers
Old 01-28-2011, 08:55 AM
jimcolt is on a distinguished road
The ratings for air plasma systems for hand cutting as compared to machine cutting are different because:
1. Piercing capability. Typically on a cnc machine the torch is mounted perpendicular to the plate, and above a certain thickness the molten metal that is blown back during the pierce will damage the fron t end consumable parts on the torch. Most cnc machines have a torch height control system that will set a higher pierc height, then index down to the proper cut height, but even with this piercing is limited. With the torch in your hand, you can tip the torch at a steep angle so the molten material will not damage the front components on the torch.
2. Duty cycle ratings. Typically in mechanized applications the torch is used more and cycled more, as the operator does not tend to get tired. If a machine is retaed for 40% duty cycle at it's full output, then it in theory can cut continuously for 4 minutes and must cool for ten minutes on its thickest rated material, on a day that the ambient temperature is at the same temeperature that the manufacturer rated the machines duty cycle at.
3. On very thick materials the speed of a plasma torch drops off considerably. 10 inches per minute is not especially slow for hand cutting, but is agonizingly slow for machine cutting!
It has been kind of a rule of thumb to rate most air plasma's for mechanized cutting at 1/2 the rating for hand cutting for the above reasons.
So, for mechanized cutting, the thing to pay careful attention to is the piercing capability. If you need to pierce 25mm material, then you will need to specify your plasma system to be able to do so, or you will experience very low consumable parts life.
The important things to look for:
1. Pierce capacity.
2. Cut speed capability on thicker materials
3. Consumable life claims
4. Killowatt output and duty cycle (not just Amperage!)
You will notice that the T-D units have a relatively low duty cycle, and if you dig into their literature you will see that a unit with equivalent amperage as compared to other brands (Hypertherm as an example) will have a much lower output killowatt rating. (calculated by multiplying Amps x load volts)...and this means lower speds and lower duty cycle.
If you can edge start, you can do 25mm materials with most machines in the 80 to 100 amp class. Most of these machines are rated to pierce about 19 mm.
Take a look at Hypertherm | Plasma Cutters | Plasma Cutting Equipment | Metal Cutting Equipment for the most powerful industrial grade plasma systems!
Jim Colt
Originally Posted by gmh265 View Post
Hey Everybody,
cheers
Old 01-28-2011, 09:58 AM
Med-Pac is on a distinguished road
We've had our hypertherm 1000 for quite a few years now. Excellent machine. Excellent support.
Need Help!- Plama Cutter Gantry Drive Unit antsals Plasma, EDM and other similar machine Project Log 9 01-08-2011 08:53 AM
Plasma Choice rockrunner86 Plasma, EDM and other similar machine Project Log 5 07-29-2010 08:59 AM
CNC Laser cutter versus CNC Plasma cutter? squale Laser Engraving & Cutting Machines 10 04-26-2009 04:59 PM
New Build Specification (Plasma/Router unit) Profpinz DIY-CNC Router Table Machines 6 11-13-2008 12:44 AM
What Plasma Cutter To Buy? CPierce18 CNC Plasma and Waterjet Machines 9 02-06-2008 05:13 AM
