Old 01-13-2011, 10:20 AM
Thessinger is on a distinguished road
adapting a plotter cutter to cut cylinders
Hello,
Would it be possible to adapt a plotter cutter so that it can accept and cut a cylindrical object? I have a thin plastic bottle, with straight sides (like a 2L soda bottle), and need to make some cuts. I thought it would be great to use a plotter cutter - the type where the cutter head moves along a single axis, and the sheet of vinyl is moved by a spinning rod. I was thinking this would be possible if you could cut a large segment out of the bottom of the machine (including the moving rod) so that it would be possible to slip the rod through the cylinder. However I am not sure if altering the machine in this way would destroy any other functions, or even if this would work at all. Any advice or opinions?
Thanks,
Tufty
Tags
cylindrical, plotter cutter, rotary
Need Help!- Rabbit hx 800 cutter/plotter riaandames Printing, Scanners, Vinyl cutting and Plotters 6 08-11-2011 07:00 AM
Vinyl Plotter Cutter it_inspector Want To Buy...Need help! 1 06-10-2008 03:42 PM
How to make your own plotter/cutter CNCadmin Printing, Scanners, Vinyl cutting and Plotters 8 09-12-2006 12:58 PM
Vinyl cutter/plotter jleiwig DIY-CNC Router Table Machines 7 11-29-2003 08:27 PM
HP Pen Plotter to Vinyl Cutter? tjstraz Printing, Scanners, Vinyl cutting and Plotters 6 08-05-2003 04:49 PM
