Old 11-25-2010, 05:40 PM
warpfactor10 is on a distinguished road
Post Rate Your Machine CNC Plasma
Hi everyone,
I need to source an entry level CNC Plasma cutter for the company I work for. We have about £15k to spend, including the Plasma cutter (which will probably a Hypertherm).
If you could Rate Your CNC Machine and software with some simple criteria it'd be a BIG Help! Feel free to add other criterion!
Rating: 1-10
1 NO WAY / awful / very difficult / useless / pull-your-hair-out
10 ABSOLUTELY / awesome / super-easy / as-if-by-magic
Plasma Unit
Make & Model:
How long have you owned it:
Approx Cost if known:
Consumable life:
Chances you'd buy it again:
CNC Machine info
Make, model and size:
How long have you owned it?
Was it turn-key or a kit?
Got a Z axis?
Build Quality:
Condition recieved:
Ease from opening the crate to first cut:
Setting up for different materials/thicknesses:
Reliability:
Accuracy (including circles etc):
Quality of cut:
Tech support from supplier:
Chances you'd buy the same again:
Software
Name/version:
Learning Curve:
Ease of use:
Versatility:
Reccommend it?:
Got any other Comments:
The company is David Dudgeon Studios, Arts and Craft fabricators in Bangor, Northern Ireland. I'm not here to advertise!
www.daviddudgeonstudios.com
Tags
cnc plasma, compare, comparison, rate, review
Need Help!- Machine hour rate Ganesh General Metal Working Machines 0 05-11-2010 03:20 PM
How can I increase the feed rate of my machine? Ranscon DIY-CNC Router Table Machines 13 03-05-2009 03:00 PM
Problem- c axis feed rate on a turn /mill machine bike G-Code Programing 5 09-29-2008 06:57 PM
Need Help!- Feed rate Ovverride also Increases rapid rate. Korellibopper Machines running Mach Software 1 01-30-2008 05:37 PM
