Old 11-10-2010, 06:04 PM
KilroyNo1 is on a distinguished road
C&G Mustang - Limit Switch Error
I've got a C&G Mustang plasma table with a Burny 5 controller and 4 torches mounted over a 12' x 24' table. We typically only use 1 torch, so we just removed 2 of the plasma torches to allow us to get closer to the edges of the table with the remaining torches. The small air lines to the torches have been capped and they, along with the signal lines, are laying neatly across the bridge. Now the Limit indicator light is lit up constantly and nothing will move without holding down the switch. All 3 of the limit sensors work perfectly. The screen displays "E-Stop" mode.
Is there some kind of feedback loop the Burny 5 requires from all 4 of the torches to enable the table to move?
Has anyone encountered an error of this sort before?
Limit switch replacement with proximity switch? Normsthename Bending, Forging,Extrusion... 3 07-11-2009 10:38 AM
limit switch error fool-around draughted LinuxCNC (formerly EMC2) 9 02-18-2009 04:17 AM
Newbie- Limit switch Error friklin DIY-CNC Router Table Machines 8 06-24-2008 05:14 PM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 05:58 PM
