I am wanting to build a CNC Plasma Cutter and am getting the parts now. I thought X was the Front/Back Y was Left/Right and Z was Up/Down. Is that the way they are supposed to be or is the y supposed to be Front/Back? Also when is the Negative numbers and the Positive numbers? Is all the way to the back and to the left the negative numbers for X and y and all the way to the top the negative for z? Thanks |
| There has been quite a few previous posts on this, search cartesian coordinates. #11 for example here. http://www.cnczone.com/forums/diy-cn...lding_cnc.html Al.
| Virtually all CNC machines utilize the Cartesian Coordinate System. You need to understand that first. X is left and right, Y is front and back, Z is up and down. Think of positive and negative values as where the cutter is in relation to the part zero. Irregardless of whether the part moves or the head moves. |
| Newbie- TOOL settings, basic questions - parameters | expart | BobCad-Cam | 2 | 08-30-2010 06:53 AM |
| Need Help!- Camsoft with Galil Basic Configuration Settings for 3 axes servo set up | Arul prakash | CamSoft Products | 13 | 06-28-2010 09:49 AM |
| Need Help!- Mach3 CV settings vs. G-100 Plugin CV settings | Bfarn | Machines running Mach Software | 7 | 12-17-2008 10:45 AM |
| Basic Aluminium TIG settings? | Normsthename | Welding, Brazing, Soldering, Sealing | 17 | 03-20-2008 11:32 AM |
