Old 10-29-2010, 04:07 PM
Cartierusm is on a distinguished road
CNC Plasma G Code Help.
So I'm new to Plasma but not CNC. I'm just using the torch on an existing machine to cut some tube miters. The problem I don't know what gcode is used for plasma, such as pausing for piercing and so on.
If any one can post a simple gcode file for a plasma cutter I'd appreciate it. a simple circle or anything will do.
Also never having done plasma before I take it if I lead it from the edge that I don't need to do a piercing with a special height and pause?
Thanks.
Old 10-29-2010, 07:04 PM
Torchhead is on a distinguished road
You can write your own G-code if you have time to burn. A better way might be to get a CAM program that has plasma features like SheetCAM. It puts in all of the special codes you need. The pause for example is standard G04. The heights (based on knowing where the torch is) are just Z moves with G00 or G01. Then you may need lead-ins and to figure the kerf offset for an accurate cut. Tube miters sound easy but it depends on how well you want the fit and what angle you want to miter to.
Downloading G-Code to LOCKFORMER PLASMA gwittlock CNC Plasma and Waterjet Machines 7 07-15-2011 06:15 PM
Need Help!- Plasma G-code reading silon132 CNC Plasma and Waterjet Machines 1 10-30-2008 07:45 AM
Plasma G-code with Artcam? coherent ArtCam Pro 4 11-22-2006 07:31 PM
Help with BobCAD V21 and code for plasma cutter brendanh BobCad-Cam 4 05-14-2006 05:50 PM
Plasma Cutter G Code MangyCoyote G-Code Programing 3 04-06-2006 10:54 AM
