Old 10-24-2010, 03:01 AM
Cartierusm is on a distinguished road
Plasma Sparks Protection on Mill?
I need to do some tube miters on Sch.80 Stainless Steel Pipe 4 1/2" OD and I thought I could use my CNC Mill with 4th Axis, Bridgeport Conversion.
I've got the Gcode done and I can easily make a mount to hold the torch on the mill, but I need to know what I can drape on the mill to protect the mill from the sparks of the plasma cutter? Any suggestions? Thanks.
Old 10-24-2010, 03:18 AM
307startup is on a distinguished road
This is going to sound fairly obvious, but...a welding blanket. Preferably one or more that you can trim to fit. Use magnets to attach the overhanging bits to the iron bits. Of course you will want enough to protect the ways, a bit like a cloth way cover.
Make a sheetmetal pan (or modify a cheap cookie sheet) to rest your fourth axis in to collect the majority of sparks/slag and you should be good to go.
Only ground directly to the parts you are cutting to avoid any spark welding of bearing surfaces.
Old 10-24-2010, 01:58 PM
That was obvious, but appreciated none the less, just wanted someone else to say it to make sure I wasn't overlooking anything. The part about the ground clamp is something I didn't think of yet, but definitely necessary. Thanks.
Problem- Sparks HobbyCNC Pro Cant Be Good droddis Hobbycnc (Products) 10 10-27-2009 06:18 PM
Do any sparks at all mean too much rpm? slashmaster Benchtop Machines 8 06-17-2009 02:23 PM
Lathe motor sparks on startup Zumba General Metal Working Machines 3 04-06-2006 12:14 PM
Tip up protection for plasma table dpaulson CNC Plasma and Waterjet Machines 0 01-25-2005 03:36 PM
Smoke and sparks? Marc Soren General Electronics Discussion 0 10-13-2003 07:46 PM
