I recently ordered a small batch of stainless sheet parts and the best quotes were from people with laser cutters. As I learned more about laser cutting, I realized: 1) Cutting things from sheet material is a fairly cheap way to do small production runs (50-500 items). 2) I don't know enough about the different methods. What I would really like is a "CNC Sheet Manufacturing Guide for Wacky-Inventor-Types" book, but doubt anything like that exists. Another option would be a spreadsheet showing each method and a series of attributes for comparison: Material it can cut And then, per material: Max Thickness Min Thickness Accuracy Smallest hole it can cut Smallest slot it can cut Smallest feature it can cut (how narrow a "fork tine" can it cut) Any taper of cut (thinking plasma) Relative cost of basic machine Estimated cutting speeds Does anyone know of any resources, or if I put together an online-spreadsheet of some sort, would people volunteer to fill in the blanks? -Jeff |
| Hi Jeff, I'd be happy to cover the wire edm portion. I do a lot of prototype sheet parts that I cut as a stack. These are small parts with features and tolerances that do not lend themselves to laser or waterjet. If you can open dxf files I can post some examples. Roy Solomon |
| That would be great! I'm especially interested in taper tolerances. My understanding with laser and waterjet is that the tolerances run _roughly_ .005 per inch vertically. I have some parts that are 3/4" high with .035" wall thickness that I'm looking to get done. Also, how does your edm work with multiple inside cut-outs? I know some edm's will self feed on existing holes. Are there any that combine a sinker for hole formation, and then wire for profile cutting? Thanks! -Jeff |
| Jeff, I have cut parts as tall as 8 inches that were straight within 2 tenths. Most modern machines auto-thread, as does the one I currently run (Mitsubishi). There were a couple of attempts to integrate a "hole popper" on to a wire edm in the mid 80's. This concept did not catch on for a variety of reasons. I usually have a stack of sheets drilled, some times our strippit turret punch press will pierce the start holes, then blank the outside. I used to screw stacks together on a base plate, lately I"ve been having our fab department tig weld up the sides, that works pretty well. |
| Having trouble cutting aluminum sheet | fastturbovet | General Metalwork Discussion | 40 | 06-14-2005 10:33 PM |
| Video of CNC laser cutting steel. Way Cool | RotarySMP | Laser Engraving & Cutting Machines | 7 | 10-06-2004 07:56 PM |
| CNC router deflection calcs and cutting loads? | Linus | DIY-CNC Router Table Machines | 1 | 09-10-2004 10:08 AM |
| CNC Router cutting Aluminum | 2Gs | DIY-CNC Router Table Machines | 7 | 08-09-2004 08:21 AM |
| home made CNC wire cutter and router | geesville | DIY-CNC Router Table Machines | 5 | 02-05-2004 08:24 PM |
