Old 09-17-2010, 07:28 PM
Beefy is on a distinguished road
Need Help Understanding Sheetcam Gcode Output
Hi All,
I'm learning the gcode which is output from Sheetcam for my plasma cutting
table. I have a touch off Z-axis for referencing the torch height to the top of
the material before each cut. I'm using the "MP3000-DTHC-SmlArcFix" post
processor.
Here's the first few lines of the gcode:
N0030 G21 (Units: Metric)
N0040 G53 G90 G40
N0050 F1
N0060 (Part: Sheetcam Tryout - Square)
N0070 (Process: Outside Offset, VISIBLE, T1: Plasma, 2 mm kerf)
N0080 M06 T1 F2000 (Plasma, 2 mm kerf)
N0090 G00 Z12.7000
N0100 X857.4000 Y942.6000
N0110 G28.1 Z12.70
N0120 G92 Z0.0
N0130 G00 Z0.1370
N0140 G92 Z0.0
N0150 G00 Z5.0000
N0160 M03
Questions:
Why is F1 (1mm per minute ?) inserted in line N0050. It's correctly set at 2000
mm/min three lines later.
What is the meaning of having a tool change on line N0080. I'm a beginner to
this but I can't see any purpose to this, I mean there is no tool change. I
would have expected just the feed rate to be set and that's it.
Line N0090 says rapid the Z-axis to 12.7 but at this point the Z-axis position
is not known, it hasn't been referenced / homed. With a floating Z-axis on a
plasma cutter the homing is the touch-off and is the top of the material, and
this is not done until after this starting on line N0110.
I think I've got the rest of the gcode worked out but the above has me stumped
at present.
Thanks,
Keith
Old 09-18-2010, 12:35 PM
Torchhead is on a distinguished road
Check the same post on the Yahoo CandCNCSupport Forum. Answered in detail
TOM caudle
www.CandCNC.com
Solidcam output weird Gcode kn6398 Solidworks 3 03-18-2009 07:55 PM
Running a gcode output file in the computer Palafox General CAM Discussion 3 06-10-2008 05:56 PM
lots of extraneous Z commands in sheetcam output mbwittig SheetCam 1 05-04-2007 02:44 AM
I have a problem with my gcode or my conversion to gcode , everything is tiny? NickLatech G-Code Programing 0 03-10-2005 12:46 PM
does deskam only output metric gcode? july_favre Carken Products (Deskam, DeskCNC etc) 1 04-23-2004 03:44 PM
